Line Lock
Old Aug 13, 2008 | 01:57 AM
C6 ROLLER's Avatar
C6 ROLLER
Default Line Lock
I bought the Cartek line lock package at Christmas time as it was a special they ran back then. I finally had it installed and will be getting my car back soon. How many of you out there have it and actually use it.
Old Aug 13, 2008 | 01:58 AM
dsp300c's Avatar
dsp300c
I have it and use it with a remote relay. Works like a champ. I would recommend their setup to anyone!!! Great product and easy to use.
Old Aug 13, 2008 | 05:22 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Use it every time at the track! Roger and the boys installed one in my C5 and my C6. DTE posted a big post a year or so ago about how to keep your diff alive and they said a line lock was important to keep the brakes from putting an uneven load on the posi.
Old Aug 13, 2008 | 12:47 PM
bunk22's Avatar
bunk22
I've got it and use it every time at the track. Love it. Actually makes it look like I know what I'm doing with my fantastic burnouts
Old Aug 13, 2008 | 01:39 PM
LS1LT1's Avatar
LS1LT1
Old Aug 13, 2008 | 02:18 PM
Julian@Cartek's Avatar
Julian@Cartek
Thanks for the props...get ready for a new set of tires!
Julian C Hormilla
(908) 317-4496
Old Aug 13, 2008 | 03:17 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Been using mine since last year and love it.
Getting your brakes bled properly afterwards however is a bit of a challenge but that has absolutely nothing to do with Cartek or the line lock kit. The issue is with the ABS unit needing to be opened properly with a Tech 2. I was able to get around it by using a Motive Powerbleeder and several panic stops before I started the bleeding process and the brakes feel like they should again.
Christopher
Old Aug 13, 2008 | 03:57 PM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
However, not sure which brand I have, Horsepower Sales installed it.
Old Aug 15, 2008 | 01:37 PM
LS1LT1's Avatar
LS1LT1
The best part about a line lock is that it's a very cost effective mod that really can help save the car from some driveline damage.
Of course the rear tires that one tends to heat a little more when they have a line lock aren't cheap.
Old Aug 15, 2008 | 01:53 PM
bunk22's Avatar
bunk22
I bought mine from Cartek btw.
Old Aug 15, 2008 | 01:58 PM
Jeenis's Avatar
Jeenis
these work for C6Zs too?
Old Aug 15, 2008 | 02:48 PM
Julian@Cartek
Yes they do
Julian C Hormilla
(908) 317-4496
Old Aug 15, 2008 | 10:02 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
We have Hurst Roll Control units with custom formed lines these prefabbed kits from Cartek are a great deal for diy guys as double flaring and bending lines is tricky if you aren't used to it and have the proper tools.
To Line Lock
