I have a small coolant leak coming from the front of the engine bay on the passenger side of the car. It is all the way up front near the plastic air dam. I am getting small puddles of coolant on my garage floor after the car has been parked for awhile.
I checked with a flashlight directly above the puddle and can't seem to find where the leak is coming from. I have changed out my Thermostat which is in that area but the connections and hose seem to be dry.
feel underneath the thermostat,, its probley leaking under it between the surfaces, just add some permex gasket sealer on the flange surface..
I had the same problem. The thermostat came with a new o-ring, and it leaked a little. We took it apart and used the factory o-ring and it stopped leaking.
