Need part number please!
Old Aug 23, 2008 | 08:11 PM
Balex's Avatar
Balex
8th Gear
Default Need part number please!
I just purchased an 05 and threw/destroyed an ac belt, can someone please tell me the correct part number and belt to buy as i cant seem to find it or get it right.
Old Aug 23, 2008 | 08:33 PM
mario7669's Avatar
mario7669
here you go this is off my 06 gm12579228
Old Aug 23, 2008 | 08:40 PM
calemasters's Avatar
calemasters
Also, since you have a 2005 MY, better check the crank shaft pulley to make sure it is fully seated.
Old Aug 24, 2008 | 09:43 AM
Balex's Avatar
Balex
8th Gear
the bolt is extremely loose, small oil leak where this is as well...
Old Aug 24, 2008 | 09:59 AM
calemasters
That is the root cause. The belt failure is secondary. Do not start enging untill the this bulletin is completed.
Service Information 2005 Chevrolet Corvette | Corvette (VIN Y) Service Manual | Document ID: 1770973
#05-06-01-001D: Check Gages Light, Battery Voltage Low, Accessory Drive Belt Slipping or Missing (Install New Crankshaft Balancer with POA Friction Washer) - (Feb 24, 2006)
Subject: Check Gages Light, Battery Voltage Low, Accessory Drive Belt Slipping or Missing (Install New Crankshaft Balancer with POA Friction Washer)
Models: 2005 Chevrolet Corvette
with 6.0L Engine (VIN U - RPO LS2)
Built Prior to VIN Breakpoint 55111039
This bulletin is being revised to update the Parts Information and include information on the new POA friction washer in the Service Procedure. Please discard Corporate Bulletin Number 05-06-01-001C(Section 6 -- Engine).
Condition
Some customers may comment on the Check Gages Light or the Battery Voltage Low indicator coming on. Additionally, some customers may comment on the accessory drive belt either slipping or being missing.
Cause
The crankshaft balancer bolt may have become loose.
Correction
Install the new crankshaft balancer with POA friction washer and a new crankshaft balancer bolt using the following procedure:
Disconnect the negative battery cable at the battery.
Remove the air duct (6).
Remove the radiator support.
Remove the accessory drive belt.
Disconnect the generator.
Remove the generator bolts and generator.
Disconnect the steering intermediate shaft at the steering gear.
Install the engine support swivel brackets( J 42451-1). Two swivel brackets are needed OR install engine support swivel brackets (SPX 7100) which come as a set.
Hoist the vehicle.
Remove the front wheels.
Loosen the motor mounts.
Install the leaf spring fixture (J 33432-A).
Disconnect the tie rods (5) from the steering knuckle (4).
Disconnect the speed sensor.
Remove the lower ball joint nut and disconnect the lower control arm from the knuckle.
Disconnect the bottom shock absorber bolts.
Disconnect the ABS module bracket bolts.
Disconnect the stabilizer shaft insulator clamp bracket bolts and shaft.
Disconnect the cooler line bolts to the engine cradle.
Install a suitable jack under the cradle.
Remove the cradle nuts.
Lower the cradle.
Remove the A/C belt.
Disconnect and remove the starter.
Install the flywheel holding fixture J 42386-A.
Remove the cooling fan bolts and fan assembly.
Scribe or mark balancer orientation.
Remove the crankshaft balancer bolt (139). Do not discard the crankshaft balancer bolt. The balancer bolt will be used during the balancer installation procedure.
Use the J 41816 (1) and the J 41816-2 (2) in order to remove the crankshaft balancer.
Place the old and new balancers on the bench and orient them the same way (i.e. face up with a weight balance hole at 12 o'clock). Scribe/mark the new balancer in the same location as the old balancer. Do not transfer weight pins on manual transmission equipped vehicles. Most vehicles will be balanced without the use of any additional weight pins. Because some balancers may have spun on the crankshaft, transferring weight pins to the same position would produce a random imbalance.
Inspect for the following conditions:
• Metal transfer to the crank post. Replace the crankshaft if metal has been transferred to it or it is damaged.
• Metal transfer or damage to the timing chain sprocket face. Replace the sprocket if either condition is present.
• Verify that the bolt does not bottom out in the crank post.
Install the new POA friction washer onto the back of the new crankshaft balancer by hand. Refer to the illustration, item 1, for proper installation.
Install the new balancer paying attention to line up the scribe mark.
Use the J 41665 and the J 41478 in order to install the balancer. Note that the threaded rod in the illustration above is from J 41478, Front Oil Seal Installer.
34.1. Assemble the J 41478 threaded rod, nut, washer and installer. Insert the smaller end of the J 41665 installer into the front of the balancer.
34.2. Use a wrench and hold the hex end of the threaded rod.
34.3. Use a second wrench and rotate the installation tool nut clockwise until the balancer is started onto the crankshaft.
34.4. Remove the tool and reverse the installation tool. Position the larger end of the installer against the front of the balancer.
34.5. Use a wrench and hold the hex end of the threaded rod.
34.6. Use a second wrench and rotate the installation tool nut clockwise until the balancer is installed onto the crankshaft.
34.7. Remove the balancer installation tool.
Notice: Failure to apply proper torque to the old balancer bolt may result in the balancer not being fully seated. This could lead to failure of this joint in the future.
Install the old balancer bolt and tighten.
Tighten
Tighten the old balancer bolt to 330N·m(240 ft. lb).
Important: The nose of the crankshaft should be recessed 2.4-4.48 mm (0.094-0.176 in) into the balancer bore.
Remove the old bolt and measure the hub to crankshaft distance.
Coat the three to five threads of the new bolt with thread locker (LOCKTITE™ 272) P/N 12345493 (in Canada, 10953488) before installation.
Notice: Be sure to follow the torque procedure for installing the new crankshaft bolt. Use of impact tools, or not using torque and angle method will result in joint failure.
Install and tighten the new crankshaft bolt.
• Tighten the crankshaft balancer bolt a first pass.
Tighten
Tighten the crankshaft balancer bolt a first pass to 50N·m (37 lb ft).
• Put a paint stripe on the bolt running from the 12 o'clock to the 6 o'clock position in order to verify the correct torque requested in the next step.
Important: When tightening for the second pass, a minimum torque of 320 N·m (236 lb ft) should be observed. If this torque is not achieved, the bolt should be replaced.
• Tighten the crankshaft balancer bolt a second pass.
Tighten
Tighten the crankshaft balancer bolt a second pass to 140 degrees using the J 45059.
Important: Recheck the position of the previously painted stripe to assure 140 degree rotation. Achieving the correct torque angle is critical to the success of this repair. Over-torquing or under-torquing the joint will result in an unsatisfactory repair.
Remove the J 42386-A Flywheel Holding Tool.
Install the starter and bolts. Tighten the starter bolts.
Tighten
Tighten the starter bolts to 50 N·m (37 lb ft).
Important: Orient the purple lead wire to the 10 o'clock position when installing.
Connect the starter wiring.
Install the starter motor S terminal washer and purple lead wire (1).
Install the S terminal nut (2) and tighten.
Tighten
Tighten the S terminal nut to 4 N·m (35 lb in).
Important: Orient the gray and rust harness leads to the 6 o'clock and 7 o'clock position.
Install the gray and rust harness leads to the solenoid.
Raise and align the cradle.
Install and tighten the cradle nuts.
Tighten
Tighten the nuts, using hand tools only, to 110 N·m(81 lb ft).
Install and tighten the engine mount nuts.
Tighten
Tighten the nuts to 65 N·m(48 lb ft).
Install the A/C belt.
Install the cooler line bolts.
Install the fan shroud assembly and bolts.
Tighten
Tighten the bolts to 5 N·m(44 lb in).
Position the stabilizer shaft and install insulator clamps and bolts.
Tighten
Tighten the stabilizer shaft insulator clamp bolts to 58N·m (43 lb ft).
Install the tie rod to the steering knuckle.
Install the outer tie rod end stud nut to the outer tie rod end stud and tighten .
Tighten
Tighten the outer tie rod end stud nut to 20 N·m(15 lb ft) to seat the stud.
53.1. Turn the nut an additional 160 degrees.
53.2. Check for the outer tie rod end stud nut for a minimum final torque of 45 N·m(33 lb ft).
Install the lower ball joint to the steering knuckle.
54.1. Tighten the lower control arm ball joint stud nut.
Tighten
Tighten the nut to 20 N·m (15 lb ft) to seat the ball joint stud.
54.2. Turn the ball joint stud nut an additional 210 degrees.
54.3. Check the ball joint stud nut for a minimum final torque of 55 N·m (41 lb ft).
Install the shock bolts and tighten.
Tighten
Tighten the shock absorber lower mounting nuts to 28 N·m (21 lb ft).
Repeat tie rod, lower ball joint and shock for the other side.
Install the tires and lug nuts.
Important: Tighten the nuts evenly and alternately in order to avoid excessive run out of the tire and wheel assembly.
Using the J 39544-KIT , tighten the wheel nuts in the appropriate sequence shown.
Tighten
Tighten the nuts in sequence to 140 N·m(100 lb ft).
Remove the support jack.
Remove the Leaf Spring Compressor (J 33432-A).
Lower the vehicle.
Remove the engine support swivel brackets.
Install the upper radiator support and tighten the bolts.
Tighten
Tighten the bolts to 9 N·m (80 lb in).
Install the coolant and EVAP lines to the fan shroud.
Install the engine cover and oil fill cap.
Install the intermediate shaft.
LOCTITE™ the steering intermediate shaft bolts and install.
Tighten
Tighten the lower coupling retaining bolt to 34 N·m (25 lb ft).
Install the generator and tighten the bolts.
Tighten
Tighten the generator bolts to 50 N·m(37 lb ft).
Connect the generator wiring.
Tighten
Tighten the battery feed cable nut to 13 N·m(10 lb ft).
Install the new accessory belt.
Install the air duct and box.
Connect the battery cable to the battery.
Perform a crankshaft variation relearn procedure.
Parts Information
Part Number
Description
Qty
12557840
Bolt, Crankshaft Balancer
1
12598831
Balancer, Crankshaft w/ POA Friction Washer
1
12579229
Belt, Water Pump, Power Steering and Generator
1 as req'd
12579228
Belt, Air Conditioning Compressor
1 as req'd
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J0720
Pulley, Crankshaft Balancer - Replace
4.6 hrs
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
Old Aug 24, 2008 | 11:51 AM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Please visit the website or contact me directly for a new setup!
Old Aug 24, 2008 | 12:14 PM
Balex's Avatar
Balex
8th Gear
Email sent...
To Need part number please!
