We say double
If the M2W switch would cause it, then there would be no difference than the factory NPP causing it. They are one in the same operation in principal. Any dealership that makes that assertion is going to open up a pandoras box with their OEM NPP.
PS: The problem you had that "no dealer could fix" back in February that you posted, what was this???
02-04-2008, 07:39 PM #3
exoticlifestyle
Junior Member
My Corvette Photos
Charlie at RPM is the best he got rid of a problem i had that no dealer or any expert could, My car runs great and i couldn't be any happier with the
results. Charlei if you read this, Thank you very much!!!!!!!!!!!!
PSS.: Something else is peculiar, you stated
"all of the after market parts were taken out before taking the car to the dealer. the car was stock when it gave me the problem".
Well, why would you take out all the aftermarket parts if it happened 'when the car was stock' ? If it occurred when it was stock, why did you install the mods with the existing problem and then take the mods back out before going to the dealer.Those two statements don't make sense. Moreover, how did the dealer know you had a M2W switch if you took out all the aftermarket parts?? Perhaps the dealership belongs to the phsychic friends network.
