Brake Question
Old Sep 3, 2008 | 05:24 PM
Mad*Max's Avatar
Mad*Max
Default Brake Question
I have an '07 A6 Coupe, my question is that when I have to end up changing my pads, will I need to replace the rotors too or is there enough meat on these ones to machine them? I tried a search on this but to no avail. Thanks.
Old Sep 3, 2008 | 05:33 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
I'd think if you changed your pads on a timely basis you wouldn't need to turn your rotors, but, yes they can be turned.
Old Sep 3, 2008 | 08:08 PM
Mad*Max's Avatar
Mad*Max
I'm not an expert but I've had auto shops tell me that you have to machine the rotors every time you change pads otherwise the new pads will wear out very quickly - I guess this is not true?
Old Sep 3, 2008 | 08:33 PM
harddrivin1le's Avatar
harddrivin1le
It's not true - unless they're warped (which you can feel).
Some argue that switching to a different pad material necessitates resurfacing (very "light" machining) in order to remove the old embedded pad material and allow the new pad material to properly seat.
On the other hand, I swapped over to different pads with my '99 Z28 and didn't touch the rotors; I had no problems.
None of that is an issue if you stay with the OEM pads...
Old Sep 3, 2008 | 08:34 PM
Mad*Max's Avatar
Mad*Max
Old Sep 4, 2008 | 04:31 AM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
I just replaced all my pads with ceramic ones and didn't machine my rotors. The car stops as good if not better than before.
Old Sep 4, 2008 | 12:15 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
There is no issue installing new pads on the same rotor as long as:
  • Same or complimentary compound pads are used
  • Minimum rotor thickness has not be reached
  • No 'warping' has been evident
  • No rotor cracks shown going to the edge
Typically speaking most pads can be used with other companies but check for sure. Of course if it is the same material, there is no problem.
Warping of the rotor which has commonly been mistaken for the material actually being 'warped' like a piece of wood, which is not the case. Warping of the rotor is typically when you have exceeded the temperature of the pad and it is leaving deposits on the face of the rotor un-evenly leaving you with a pulsation in the pedal. New rotors, or a fresh machine of the face is the only way to achieve this.
Let me know how I can help!
Old Sep 4, 2008 | 12:41 PM
mksz51's Avatar
mksz51
Warping can also be caused by incorrect torque on lugnuts.
Old Sep 4, 2008 | 04:56 PM
Mad*Max's Avatar
Mad*Max
This is all very informative for me, and has also dispelled a myth for me.
Old Sep 4, 2008 | 05:08 PM
Former Vendor
While some of it can be rather long winded, there is some good reading on StopTech's site.
Tech. White Papers
Old Sep 4, 2008 | 05:09 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
FYI, when I was at Spring Mountain last Dec, I asked them how long their tires lasted. The chief instructor said they get about 1,000 miles per set, and they change pads when they change tires. They do not resurface or replace rotors when they change pads.
Old Sep 4, 2008 | 10:50 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Last time I looked, the Chevy shop manual specifically said to NOT machine the rotors unless they were badly scored or warped.
Old Sep 17, 2008 | 07:51 PM
socalspringmountain's Avatar
socalspringmountain
Premium Supporting Vendor
Machining rotors is not always necessary but you can if you want. It is ideal to machine them when you change pads because it gives you a flat surface on the rotor which will help your pads wear evenly. The problem with machining rotors is that it makes easier for them to warp in the future. For most driving applications I would not machine rotors unless they are warped which you will feel in the pedal and steering wheel when you apply the brakes.
Jordan
Old Sep 17, 2008 | 11:27 PM
danl72's Avatar
danl72
Old Sep 17, 2008 | 11:34 PM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Jordan
I agree!!
Old Sep 18, 2008 | 08:11 PM
Mad*Max's Avatar
Mad*Max
Jordan
ok
Old Sep 18, 2008 | 09:35 PM
KB9GKC's Avatar
KB9GKC
Douglas in Green Bay
To Brake Question
