Brake issues, what do you think.
Old Sep 6, 2008 | 09:24 PM
NV MY C5's Avatar
NV MY C5
Senior Member
Cruise-In V Veteran
Default Brake issues, what do you think.
I have a 08 Z51 coupe, manual trans that I mainly use for autocross. This issue has existed since new, the car now has 2500 miles. I dont notice any issue on the street, only when autocrossing.
When I jump on the brakes hard the pedal is solid the brakes do not grab right away. It takes about a second for the pedal to get softer and the brakes to grab. It is almost like the car is telling the brakes to wait a second before engaging. It does not do this every time I slam the brakes only about 75% of the time.
Any ideas would be appreciated!!!
Thanks Mike
Old Sep 6, 2008 | 10:31 PM
NYC6's Avatar
NYC6
What pads do you use?
Old Sep 6, 2008 | 11:06 PM
NV MY C5's Avatar
NV MY C5
Senior Member
Cruise-In V Veteran
I started with the factory pads, I had this problem but thought it might be a lack of bite. I went to HPS+, they were too agressive and set the abs into ice mode almost every time I braked hard. I am now running HPS pads.
The closest thing I can relate this feeling to is on my last C5, I replaced the motor with a racing crate motor. The motor ran great but I had a real hard brake pedal. I later found that a vacuum cap had been left a port on the manifold (to the booster).
Old Sep 6, 2008 | 11:15 PM
tmak26b's Avatar
tmak26b
HPS ha, that's your problem. Those are some of the worst pads ever, its even worse if you try to drive it in the rain.
Old Sep 7, 2008 | 12:31 PM
NV MY C5's Avatar
NV MY C5
Senior Member
Cruise-In V Veteran
I really dont think its the pads. The pedal feels just like the booster has no vacuum. It is fine except when trying to brake after being at WOT. I did check the check valve and it seems to be fine.
Old Sep 7, 2008 | 12:44 PM
Morrisman's Avatar
Morrisman
It could be a brake fluid issue.
I switched to Motul 600. I brake hard and my fluid neverboils.
Old Sep 7, 2008 | 12:48 PM
NV MY C5's Avatar
NV MY C5
Senior Member
Cruise-In V Veteran
I plan to make that change over the winter but this has happened since new. Noone else I talked to has had a problem like this.
Old Sep 7, 2008 | 01:51 PM
danl72's Avatar
danl72
Old Sep 7, 2008 | 01:57 PM
LS3FORME's Avatar
LS3FORME
COMPRESSION OF THE BRAKE FLUID, BUBBLES, IN FLUID AND BOILED FLUID.
motul or brembo has a high compressability.
To Brake issues, what do you think.
