B & M shifter bushing problem
Old Sep 6, 2008 | 11:41 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Default B & M shifter bushing problem
This morning, I had problems hitting 3rd gear and finding 1st at the stop lights, so I guessed the B&M shifter mounting bolts had come loose.
Upon disassembly, I was right but what I did not expect was the rear mount B&M bushing was completely GONE!!!!
Upon removal of the shifter to fabricate a new bushing, I also discovered the front mounting ear was bent slight as a result the missing rear bushing and taking the full force of shifting.
The factory bolts and bushings are, in my opinion, just too small. The factory torx bolts also have a tendency to loosen. I am sure Loctite would help but there is simply not enough metal for long term reliability. Remember, there are only 2 relatively small mounting bolts that attach the thin cast aluminum OEM shifter frame to the torque tube.
I plan on fabricating reinforcing metal plates top and bottom to replace the B&M bushings and reinforce the OEM mounting points. Also, drill out the threads on the tabs welded to the torque tube and thread in a bigger bolt. This should stop this from happening again.
Anyone else have this problem?
Old Sep 7, 2008 | 07:52 AM
mksz51's Avatar
mksz51
I've not had the problem since I don't have the B&M shifter. Let me be the first to ask: Have you considered changing to the MGW shifter? The mounting plate on that shifter is stout and the shifter is extremely precise and well built.
Old Sep 7, 2008 | 09:30 AM
Mez's Avatar
Mez
Perhaps I was not very clear. Its not anything from B&M that failed. The two torx bolts that came loose are the original GM bolts that attach the OE cast aluminum frame to the torque tube. The OE bolts were designed to be installed once perhaps and after reused, they tend to loosen up over time. Loctite would help but in my opinion, the factory aluminum bracket and bolts are just too small.
Old Sep 7, 2008 | 09:52 AM
mksz51's Avatar
mksz51
Got it - I did misinterpret your original post; my bad.
I've not heard of this before or seen any similar posts - how hard are you banging on that shifter?
Old Sep 7, 2008 | 11:01 AM
Mez's Avatar
Mez
Not hard at all. I don't race the car or speed shift it.
All short throw shifters require more effort, however. I am very sure the problem is the type of bolts which they used and probably were not designed to be reused.
Old Sep 7, 2008 | 11:46 AM
Just Enough's Avatar
Just Enough
There is a rubber/plastic angled cap like bushing glued on the bottom of the shifter box, it locates in a long welded slot on the torque tube. This can fall off if the shifter box is removed. If it has fallen off too much load will be transferred to the two top torx screws and they can either loosen, break the oblong zinc washers or break the ears off the shifter box, also when the box comes loose it will loose alignment and cause the bushing and seal in the exit of the box to wear quickly.
Old Sep 7, 2008 | 12:11 PM
Mez's Avatar
Mez
I skipped this point that I found this plastic sleeve all the way down on the big center plate directly beneath the shifter so it must have fallen off when I removed the shifter yesterday. I reglued the plastic piece to the shifter box with contact cement, so it shouldn't fall off again.
This locates the bottom of the shifter box to the torque tube and keeps it from moving down, twisting, moving forward or rearward. But it won't prevent the shifter box from lifting up or from rocking front to back if either one of the torx mounting bolts comes loose.
To B & M shifter bushing problem
