Leaking Transaxle
Old Sep 9, 2008 | 01:08 AM
Maj. Payne N. Diaz's Avatar
Maj. Payne N. Diaz
8th Gear
Default Leaking Transaxle
Hey Guys,
Anybody had a leaking transaxle/diff on a recent 6 speed auto or any info on the above?
I knew I should have stuck with a manual!
Old Sep 9, 2008 | 08:57 AM
Xlr8yourC5's Avatar
Xlr8yourC5
Not sure what the leak looks like but just a FYI when I first bought my 05 it appeared to have a leak at the diff (stain)
- turned out to be from overfilling (vent) from original factory fill apparently
I replaced the fluid (with amsoil, fix for common issue with chatter on tight turns) - verified proper level (appx even with fill plug) - 2K miles later no leak seen (I steam cleaned off the diff area when I did the fluid change - no sign of a leak still...)
Old Sep 9, 2008 | 10:03 AM
haljensen's Avatar
haljensen
It's not really a transaxle, it is two seperate units. The transmission is a seperate casting bolted to the differential housing and they each use a different lubricant.
One or the other (or both?) could be leaking. You or a Dealer will have to determine which is leaking and where it's leaking. My '05 had a differential leak at the rear cover, the Dealer replaced the gasket, it still leaked so they replaced the cover and the gasket, that cured the leak.
Old Sep 9, 2008 | 03:45 PM
VET4LES's Avatar
VET4LES
I had the same vent discharge after a trip in hot weather.
The vent is on top, drivers side and looks like a nickle.
Old Sep 9, 2008 | 04:14 PM
DaveC6's Avatar
DaveC6
My '07 A6 leaked a few drops from the rear end a couple months after it was new. Then nothing more since. I read that it is not all that uncommon.
Old Sep 9, 2008 | 06:36 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Originally Posted by Maj. Payne N. Diaz
Hey Guys,
Check out the color of the fluid - the differential uses gear oil (which is gray from what I recall) and transmission fluid is pink.
To Leaking Transaxle
