I have a friend I race w/ who's 2006 6MN only had bolt ons CAI, headers, etc. broke 2 axles, clutch failed & finally dropped a piston . Some happened at the track, some happened off, but obviously the stress of hard driving was no doubt the cause of these failures whether it happened at the time of racing or through weakened condition of the car from the abuse a car takes at the track. This guy is an excellent driver who broke into the 11's w/ bolt ons & 6MN (not easy). Luckily he was covered under warrenty, but in your case w/ the mods you've done no dealer is going to cover any driveline failure. I have a 2005 making 450 rwhp, but w/ street tires, & it has held up to a lot of abuse track & street, but mostly on the street. I remember the 1st time I tracked the car & was very concerned about the abuse a car takes when you track it, particularly after I left. Now does that keep me from going, HELL NO, I bought the car to do performance driving, so if it breaks, I'll fix it & carry on! Have fun w/ your car & more than likely you'll accomplish your goals, not break, & enjoy the hell out of yourself.
I started off with a 2006 Z51 MN6 with a H/C package with fly cut pistons, 4.10's, 1000 H.P. clutch, 100 nitrous (never used), plus other bolt-ons, and a CCW drag package. This motor put out 462.5 NA RWHP. Now for the breakage. Left side half-shaft, busted rear housing with all internals destroyed, in two weeks another rear failure due to the first set-up being wrong, and a destroyed motor due to failure of a fly-cut piston. This car has only had 8 drag strip runs. My car is currently at Mayhem Motorsports in Raleigh, N.C. having a 402" forged motor built with a DTE rear installed. This motor as planned should have at least 520 NA RWHP and hopefully be more bullet proof than my previous parts.
I am sorry to hear this but appreciate you letting people know the perils....can you expand on how the fly cutting caused motor failure?
I am considering fly cutting and this is the first failure I recall seeing.
Ok I think we just converted a potential racer into a lifelong waxer.
All that was left in 1 cylinder was the rod and the wrist pin. No evidence of any piston parts were in sight when looking down into the block. The head and block were damaged beyond repair. I was told not to flycut the pistons, but the motorbuilder said it was necessary to alleviate clearance problems. If you're going to this extreme to build a motor, build a forged bottom end with the correct forged pistons. Again, I'm starting out with a new motor and RPM rear components, plus a lot of other exterior mods to include Z06 rear fenders, CCW T10's with 345 PS2's in rear, and after market hood and stripes. Other mods to numerous to mention without a detailed reviev.
Reason: change
From: NJ..."the way I saw it, everyone takes a beating sometimes."
This is strange and the first I've heard of such an incident due to fly cutting. I have stock fly cut pistons and pushing more power than you, minus the juice. I know several other builds with fly cut pistons and even more power. Is it possible it was an isloated incident. Maybe a faulty part or bad flycutting job? Why just the one piston, why not all 8 or at least a few more? Was their a diagnosis as to what caused the failure or was it just chalked up to the fly cutting?
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Originally Posted by AintQik
Also remember peak numbers don't make fast cars, area under the curve does. A dyno sheet might help.
Surprisingly enough, up until very recently my car hadn't seen any dyno tuning and I was able to hit my 11.21 without it.
A few weeks ago I did have a local tuner take a look at my car on the dyno but it was more for the purpose of validating the tune in my car than anything else. The funny thing is that my car ended up dyno'ing less this time around than it did last year (410 vs. 417 rwhp) but I'm guessing that's probably due there being no 1:1 ratio in my car as well as different dynos and outside air temps.
11.2 with only 410-417rwhp?! And Dennis' 10.9 with only 408+rwhp!! Damn you auto guys.
That's why I'm always telling this to people at the track - it's not so much about how much you make but how much you can effectively get to the ground.
Its how you get it to the ground that counts for great ET`s.
If you guys knew how much rwhp I have and my best times you would get a good chuckle.
My point wasn't about dyno tunes, just looking at his dyno curve to see where and how it looks. I remember Dave formally from Cartek looking at my curve and saying, "this car will run 10.6". Its because of where the thing hit and how broad the power and torque were. My peak numbers were not very impressive.
You all make another very good point. If you can't get it to the ground you just aren't going to go fast. A powerglide, a 1800 pound car with the right suspension and 450 hp and I will eat your lunch all day
