402 block question about compatability between C5 and C6
Old Sep 14, 2008 | 10:39 AM
NW_Vettes's Avatar
NW_Vettes
Default 402 block question about compatability between C5 and C6
I'm wanting to put a LS2 402 in my 2006 C6 manual and I found a complete 402 from a C5 for sale with all supporting mods.
Will this hook up to my C6? If so what would I need to purchase extra to swap out the motors? Thanks!
Old Sep 14, 2008 | 11:41 PM
tjwong's Avatar
tjwong
You could get a set of ported LQ9 heads which would drop the compression down some. Then you can boost it to 10 and be OK. I wasn't sure which car you were talking about until you linked it to that ad in Craigslist. You could use that block, I believe its a good engine from Texas Speed, and it made decent power on my dyno.
Tom
Old Sep 15, 2008 | 02:00 AM
SpinMonster's Avatar
SpinMonster
A C5 uses a 24x reluctor wheel and the 2006 needs a 58x.
Old Sep 15, 2008 | 11:05 AM
NW_Vettes's Avatar
NW_Vettes
That can be switched out easily?
Old Sep 15, 2008 | 12:52 PM
Jon@RedlineMotorsports's Avatar
0Jon@RedlineMotorsports
Former Vendor
as easy as replacing the crankshaft......
To 402 block question about compatability between C5 and C6
