Race Ramps
As you can see from the pic in my sig below, my '08 Z51 is lowered on stock adjusters about 3/4" in the front. When it was corner-balanced (for track events), the rear couldn't be lowered as much as the front (even with the rear adjusters maxed out). This increased the car's rake, lowered the front spoiler to the point that I scrape a lot on the street.Even so, my spoiler barely scrapes when driving up the 2-piece 56" RaceRamps, just like GotVett? described above. I have never bothered to use supplemental boards, either.
I've even BACKED up the ramps (rear tires on the ramps) to work on the back end, which puts the front spoiler even closer to the ground while backing. But again - there's no more harm then I get entering my steep driveway or negotiating most speedbumps.
Remember that the 3-part rubber spoiler is designed to take a lot of abuse. It's inexpensive and easy to replace when the time comes.
I've never used ramps before, but these RaceRamps are really a great, safe tool. The 2-piece design makes for easy access to what you need under the car from the sides, too. I wouldn't hesitate to buy them again.
They don't look that much different from those Rhino ramps that Walmart sells for like $40, otherthan the fact it's longer and 2-piece.
No bashing or complaining...
Just saying it's a lil' too expensive for a cheap guy like me.
Dan
Dan
