Coil Relocation Re-Visited
Old Sep 29, 2008 | 11:55 AM
AintQik's Avatar
AintQik
Default Coil Relocation Re-Visited
Can somebody host a Power Point for me real quick? PM me an email. I can't get to any of the hosting sites not can I figure out how to make a power point save on this site like a jpeg.
Anyway, somebody had asked me for a diagram of the way I set up my coils and I wanted to share one. Its about $35 in parts and all you need is a welder. At first I said you did not need new wires, but since then I have decided I'm more confortable with 2, 2" longer wires because of where the brackets are mounted. They mount in the holes above the exhaust manifolds in the heads. Again, not for everyone but I was asked.
Parts List
12" of .5" boxed tubing
12" of 2" wide steel plate. I forget the gauge
2' of threaded rod
16 chrome acorn nuts and washers
8 nuts to fit threaded rod
6" .25" pvc pipe for spacer
4 .5" alm spacers between head and bracket
4 bolts for bracket to head
Everything except the chrome parts is available at Lowes or Home Depot. None if this is going to make sense unless the diagram gets hosted. If I could weld better I'd make them for ya. I'm getting there though
Only issue I see is the plug wires. Making the harness longer is no big deal. Since I run custom wires I can have them any length I want. If you were doing thsi on the cheap, I would suggest making your own wires with a Taylor 8.8mm kit and some appropriate boots and sleaves.
Old Sep 29, 2008 | 12:08 PM
AintQik's Avatar
AintQik
Sent ya a PM requesting email.
Keep in mind there is a bunch of different ways to do this, and you can go with various different methods from here. This should get you started, its simple and it works. On my car I could not find a suitable mounting point off the motor so this is why I did this. I had another, mammoth of a bracket but it was ugly and probably not required. I actually dreamed this solution and so far, it works pretty good. Most of the bracket is hidden so if you bubblegum a weld it doesn't matter.
Old Sep 29, 2008 | 12:33 PM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Old Sep 29, 2008 | 03:07 PM
AintQik's Avatar
AintQik
Thanks Craig. If anybody has any questions let me know.
Old Sep 29, 2008 | 06:33 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
that looks good, there is only 1 welded piece??
were does the 1/2" box tubing go?
thanks
Old Sep 29, 2008 | 07:17 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
where does the 1/2" box tubing go?
thanks
I would guess that the diagonal piece, with the red and black lines on it, is the 1/2" square tubing. If Craigster could post some AintQik photos of the real thing, that would probably help a lot.
Old Sep 29, 2008 | 07:49 PM
Craigster05
If he sends me any, I will post them up.
Old Sep 29, 2008 | 08:36 PM
cmonkey713's Avatar
cmonkey713
I would like to see too!
Old Sep 30, 2008 | 08:52 AM
AintQik's Avatar
AintQik
Yes, the box tubing is the diagonal piece. Its welded to the flat steel. Only one welded piece per bracket, 4 welds. I told ya it was simple and effective!
Old Dec 9, 2012 | 09:35 AM
Vital Velocity's Avatar
Vital Velocity
St. Jude Donor '11
Would love to see some pictures psealing@gmail.com
Old Dec 9, 2012 | 01:29 PM
victorf's Avatar
victorf
He had a unique idea!
But the anchor attachment was existing bolt holes on head - direct heat conduction - that is something you might want to avoid! Coils will get hotter than directly mounting on top of the valve covers!
Unless you are not concern with heat?
To Coil Relocation Re-Visited
