Harmonic balancer ??
Old Sep 29, 2008 | 10:47 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
Default Harmonic balancer ??
Has anyone noticed how much their HB wobles. I think mine is a little shakey
Any ideas about this. The dealer said its ok.
TIA David
UPDATE:
I just came from on old friends whom is a mechanic and not a shade tree type. Vic took one look and in .50 of a second he said" %^$&^. That is no good". He explained that maybe the key is already worn and maybe the crank would need to be replaced.
Old Sep 29, 2008 | 11:22 PM
Walt White Coupe's Avatar
Walt White Coupe
Many have noticed how much the pulley wobbles. Try a search and you will find a lot of threads.
What I learned from my experience with a failed flexible coupling in the harmonic balancer is that there isn't a hard and fixed limit for pulley wobble. Usually, it's only when the belt starts chirping that people realize something is wrong and needs replacement. The repair is the same as the "loose crank bolt" problem. Replace the harmonic balancer. A full day job. When I checked mine to see how it's running after about 10,000 miles since replacement and it was still running dead true. The ribs on the pulley should look still while running.
Old Sep 30, 2008 | 08:02 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
My C-5 had a little wobble but wasn't chirping or throwing the belt. My '07 with 15Kmiles runs dead true.
Old Sep 30, 2008 | 09:02 AM
theVcar's Avatar
theVcar
St. Jude Donor '08
does this mean the pulley is bent?
Old Sep 30, 2008 | 09:06 AM
Michrider's Avatar
Michrider
I've seen many that looked like they were wobbling, but it was really an optical illusion. If it was really out of whack, it wouldn't last another 10 miles. Look at the pulley grooves.
Old Sep 30, 2008 | 09:57 AM
theVcar's Avatar
theVcar
St. Jude Donor '08
what am I looking for on the pulley and should it be running?
Old Sep 30, 2008 | 10:37 AM
Walt White Coupe
Car should be running. Get a good flashlight and from the passenger side shine the light down on center of the rotating pulley where the belt rides. The pulley has parallel ribs in it and they should look stationary as the pulley rotates in a best case scenario.
Old Sep 30, 2008 | 11:02 AM
theVcar's Avatar
theVcar
St. Jude Donor '08
will do
Old Sep 30, 2008 | 01:55 PM
herbie1057's Avatar
herbie1057
Mine was replaced at 25,000 miles. It was so bad that it shredded the belt!
Old Sep 30, 2008 | 02:58 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
I have 38k and I wonder if I should have my mechanic do a change of belt and pulley. Under ext warrenty
Old Oct 1, 2008 | 02:23 AM
aTX427
Guest
Posts: n/a
I have a ATI Super Damper with 10% accessory under drive available in the for sale section if you want to upgrade.
Old Oct 1, 2008 | 09:40 AM
theVcar's Avatar
theVcar
St. Jude Donor '08
Not familiar with that. I only know what a HB is. What is this upgrade and 10% assc? some one explain please
TIADavid
UPDATE:
Old Oct 1, 2008 | 11:12 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
The balancer is on order with the bolt. It is like one sleeve inside another and b/t the sleeve is rubber, and the rubber is slightly broken loose.
Old Oct 2, 2008 | 08:19 AM
davekp78's Avatar
davekp78
TIADavid
UPDATE:
The pulleys are not keyed. Crank is almost certainly OK.
We need to be careful with the advice of people who are not familiar with the LS series engines. They are different in a few areas.
Old Oct 3, 2008 | 10:48 PM
aTX427
Guest
Posts: n/a
TIADavid
UPDATE:
ATI is top of the line in harmonic dampers (balancers). The 10% accessory underdrive will slow down the accessories (parasitic power loss) and free up 5-10hp.
Old Oct 4, 2008 | 11:49 AM
theVcar's Avatar
theVcar
St. Jude Donor '08
[QUOTE=WoodChuck2;1567344017]
TIA David
Crank pulley NEWSFLASH. b/dates & Vins
THIS WAS POSTED BEFORE, CRANK BOLT PROBLEM
Per Corvette Brand Quality Mrg. Corvettes built before 12/13/04 and VIN #s before5511039 will need to have the PI 3288A performed.
This info has not been released yet but is the correct window and will make print very soon. Manual or auto will make no difference they will will both need repaired
Remember You heard it first at "Corvette Forum"
ms/z51/auto #10985
I have 06 man
To Harmonic balancer ??
