Ls3 427
Old Oct 1, 2008 | 11:07 PM
jasonprobasco's Avatar
jasonprobasco
Default Ls3 427
I may have a chance to pick up a bare LS3 block cheap. I've been considering a stroker for my car and I'm looking for some input. I'm leaning toward a 402 LS2, but a 427 is much more appealing. I know I can get a stroker kit for an LS3 ,4.065" bore with a 4" stroke to make a 418 or 4.065" bore and a 4.100" stroke to make the 427. Although, from what I've read on CF that stroke seems to be less favorable, and I'm not trying to slam anyone with that stroke, I'm sure it works fine. My question is has anyone bore the LS3 to 4.125", the bore of the LS7. That combined with the 4" stroke will give me the 427 I'm looking for. It would require boring the block .060"...is that too much? I've looked for any info on a LS3 427 that this forum has to offer and there doesn't seem to be very much. I appreciate any info I can get.
BTW...I don't have the money for an LS7 swap. I know that'd be the best way to go.
Old Oct 1, 2008 | 11:26 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
its been done.
Old Oct 1, 2008 | 11:27 PM
tjwong's Avatar
tjwong
You can resleeve the block to get the 4.125 bore then use a 4" stroke crank of your choice to get the 427. Then all you need to do is to decide on which heads. A good alternative and relatively inexpensive is a set of the CNC ported LS3 heads and a LS3 intake. It will make tons of torque and power. I recently installed a 418 LS3 into a newer C6 with the same heads and it made excellent power and torque across the board.
Old Oct 1, 2008 | 11:33 PM
LS1LT1's Avatar
LS1LT1
Personally I would only go 418 (416?) with the LS3 block, I think the rod angles generated by the crank needed to bring it to 427 are a little much. Though it will work.
Old Oct 1, 2008 | 11:35 PM
02gt350's Avatar
02gt350
i have an LS3 416....427 has been done out of a LS3, but has its issues...i have done the research
If you want a 427, stick to a LS7 block.
Old Oct 2, 2008 | 01:27 AM
Tavarez's Avatar
Tavarez
I don't understand aren't they basically the same block? There are ls2 427's all over the place that are resleeved and stronger than an ls7 427
Old Oct 2, 2008 | 03:23 AM
LS1LT1's Avatar
LS1LT1
Yes, the LS2 and the LS3 blocks aren't all that different in basic design but the LS3 does have the larger bore of course making it an extra 12 cubic inches closer to that magic 427 number than the LS2.
But I think what '02gt350' was referring to is what it takes to get to 427 when starting with an LS3 (or LS2) block. And as far as sleeving goes I don't anyone here even assumed you were referring to sleeving as a means to get there, just using a new crank (4" stroke) in an otherwise stock LS3 block which is how most now build a 416-418.
Sleeving is whole 'nother approach.
Old Oct 2, 2008 | 03:24 AM
LS1LT1's Avatar
LS1LT1
I don't think that can be done safely, might thin out the cylinder walls/spacing too much.
Old Oct 2, 2008 | 07:55 AM
1.8t's Avatar
1.8t
Agreed. Go 418 if your staying n/a and if your planning on a power adder, go with the 416
Old Oct 2, 2008 | 08:47 PM
02gt350's Avatar
02gt350
Old Oct 2, 2008 | 08:48 PM
02gt350's Avatar
02gt350
call LME or Scoggin Dickey......they can tell you all the answers to yoru questions
Old Oct 3, 2008 | 09:05 AM
Jon@RedlineMotorsports's Avatar
0Jon@RedlineMotorsports
Former Vendor
Incorrect. adding a 4.0 crank to the stock 4.065 bore will yeild 415 cubes.
A 4.1 stoke (which is too much IMO) will yeild 426. We don't go bigger than 4.0 in our LS3s
Yes, it absolutely is too much
Old Oct 3, 2008 | 12:31 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
If you have your heart set on an 427 use the LS7 block, if not you can easily do a 416-420 cu with an LS3 block. I would also stay with a 4 inch stroke no matter which block you end up with.
Old Apr 11, 2009 | 07:54 PM
valdeztke's Avatar
valdeztke
So for those using an LS3 block to get a 427 are building motors that are likely to fail (Charlie@RPM, A&A, etc)? Reason I ask, is that I'm looking at buying a car out in CA w/ a LS3 427.
Appreciate any feedback.
Old Apr 11, 2009 | 09:07 PM
johnodrake's Avatar
johnodrake
Moderator
Which is why I don't have a 427ci LS3
Old Apr 11, 2009 | 09:16 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
I have a Katech Ls2 427 sleeved and it is a great piece.
4.125 bore X 4.0 stroke, I love it!!!
no problems at all, call Jason at Katech !!!
Old Apr 11, 2009 | 10:18 PM
valdeztke's Avatar
valdeztke
Can someone expand on this a bit...I'm not quite sure I understand what this means for longevity or dependability.
To Ls3 427
Old Apr 12, 2009 | 10:53 AM
QuikZilver's Avatar
QuikZilver
I looked at the different options for stroker LS3 short blocks. I decided to go with a 418 with steel top rings. I use my 08 as a DD and for drag racing. I wanted the option to add power adders (NOS, Turbo, SC, etc.) and the 427 LS3 was not recommended for FI. Texas Speed offers both the 418 LS3 and 427 LS3. The 418 I am having installed is coming from TS. Maybe give them a call as well and discuss your options.
Old Apr 20, 2009 | 01:38 PM
valdeztke's Avatar
valdeztke
Anyone? Redline? ECS?
Old Apr 20, 2009 | 02:12 PM
Sparo2's Avatar
Sparo2
Doesn't the strength and dependability of the block also depend on how it was resleeved? ....Using dry or wet sleeves.
I've heard they have even bigger than 4.125 bores for the LS2/LS3 blocks and turn out to be much stronger than the LS7 block itself.
Correct me if i'm wrong though.
