air bag warning light on
The problem was not the tensioner but the connector. The dealers tech used his tech 11 and pulled a tensioner code because the circuit was open at the connector. When he installed the new tensioner he made a good connection that lasted five months.
This is a letter that GM admits they know what the problem is but refuse to do anything about it.
Hi Les,
I am sorry that it has taken me sometime to get back to you about your air bag light, I had to speak with internal resources.
The air bag light concern is caused by the seat belt connector under the drivers seat coming loose. There was a change made in 2008 that moved the connector that helps some but did not completely remedy it. It can also be seen in fewer numbers in 2008 – 2010. It was driven by the connector being placed directly under the seat cushion. When a customer uses easy exit or memory so the seat moves at each door opening it will work the connector loose over time. The fix was to attach it to the seat frame so it did not get drug across the bottom of the carpet. In 2008 they made the wire a little longer to move the connector out of the way. I am not aware of any discussion for a recall or customer satisfaction action because it was self-declaring.
I am sorry this is not the resolution that you wished for on this matter. I did look into the concern and I did speak with the appropriate departments. I am sorry to be the one to bring you this news. I do thank you for being diligent in reaching out to me.
Hi Les,
I put a zip tie around each one.(there is one yellow connector under each seat and yes it clips to the round bar.
I have not had the light come on again since zip tying the connectors. I do not use the easy exit/entry feature on the power seats though so my seat never really moves unless someone pushes the driver 2 button. All that back and forth movement is probably what causes the connection to get loose over time.
It's an easy fix and saves a lot of frustration and expense at the dealership
Make sure to file a complaint with the NHTSA.
http://www.nhtsa.gov/Vehicle+Safety/Recalls+&+Defects
I strongly suggest all owners do this fix asap, to avoid any seat issues later on, including the airbag connector and frame wires ruining the foam. And since the problem will still exist, I suggest the following, which is what I did:
1. Lowering the seat all the way is useless. You'd be sitting on solid stuff, as I mentioned. Instead, raise the seat until you feel your butt barely bottoming out, meaning you don't give up on hardly any height, BUT will gain a lot in comfort. You still wouldn't have much cushioning if car bounces up and down, but it'd be way better. I feel like driving a truck if I drive any higher, so that was an acceptable compromise to me.
2. If you still want to use the seat all the way down but need to adjust it, raise it a little first, then slide it front or back, then lower it again. That way you avoid dragging the crap out of everything under the seat, potentially damaging something. I should have taken a picture of the carpet when I removed my seat with only 500 miles on the car. It was completely flattened, compressed to an unbelievable thickness.
3. If you have the seat at the bottom, DO NOT use 'easy entry'
. If you do what I did, I guess it could be used with much less concern of a future issue. Good luck.
. If you do what I did, I guess it could be used with much less concern of a future issue. Good luck.http://www.nhtsa.gov/Vehicle+Safety/Recalls+&+Defects
