check engine and lambda ?
Old Oct 6, 2008 | 03:29 PM
arampl's Avatar
arampl
Default check engine and lambda ?
Hi
I have problem with check engine light ?
The Lambda after catalytic converter shows exactly the same what lambda before ?
I have VENOM filter installed by previous owner, is this may be a reason ?
Rafal
Old Oct 6, 2008 | 03:34 PM
AintQik's Avatar
AintQik
Exactly the same what?
What is the code? If its saying the y isn't changing its trying to tell you the cat is not functioning. Does it still have CATS? You mention it had mods from before, if there are no CATS you need to disable the code in the tune. Tough to say for sure without looking at it. Could be a few things.
Old Oct 6, 2008 | 11:28 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Are you running hi flow cats? How are you reading the O2 sensors? You would have to be reading both a front sensor and a rear sensor at the same time to know they are reading the same. That sounds like a lot of trouble when all you have to do is turn off the rear sensors with some sort of tuning software or handheld.
To check engine and lambda ?
