LS2 vs LS3
Old Oct 11, 2008 | 12:50 PM
jpee's Avatar
jpee
Originally Posted by Vetter 1
I'm happy with the LS3 so far. I got a 11.94 a couple of weeks ago at E-town's Wednesday night Test and Tune. Was only able to run twice that night. This is with a Vararam and tune. Still running Goodyear run flats and traction control ON. Don't know what to do or how to run it next. Was going to mod my car with things that is working for you John. But, your doing mods faster than I want.
NO.... I'm not, all I've done so far is the 160 T Stat, and a Vararam, and Cartek had it on the Dyno... Oh I also bought 18x9" wheels for the rear (Thin Spoke Polished Aluminum) to match the fronts, and a set of DR's.. so actually we are at the same level of Mods..
I plan on going to E Town next Sat (Oct 18) to see how it runs on the DR's
It seems like you are definitely faster with the LS3 than my LS2 .. The converter won't go on until the winter (I Hope)
Old Oct 11, 2008 | 12:57 PM
Katech_Zach's Avatar
Katech_Zach
Premium Supporting Vendor
C7 of Year Finalist (track prepared) 2019
Originally Posted by canandy2
Tony B4 help me out if I'm wrong. The LS3 has the Z06 heads, So I believe the bottom end of the motor is the same as the LS2. 2 tired to look up anything else
Originally Posted by Rock'n Blue 08
I think the ls-7 and the ls-3 are the same except the Valves are 1mmbigger on both for the ls-7
The LS3 and LS7 heads are not the same.
LS7 is CNC ported from the factory, LS3 is as-cast
LS7 intake port height is different
LS7 has an offset intake rocker
LS7 has a 12 degree valve angle, LS3 has 15 degrees
LS7 valves are 2.200/1.610 Titanium intake/Hollow stem, sodium-filled stainless steel exhaust. LS3 are 2.165/1.590 Hollow stem stainless steel intake/Solid stainless steel exhaust
LS7 has 70cc combustion chamber, LS3 has 68.7
Originally Posted by AU N EGL
Doesn't the LS2 have the LS6 (243 )heads except with SS valves. The LS3 has different heads with bigger valves ?
Yes, LS2 and LS6 heads are 243 castings.
LS6 and LS2 valve sizes are the same, but the LS6 has hollow stem valves, sodium filled on the exhaust
Originally Posted by Jimmyz28
I believe this is correct. I've been told the LS2 is the LS6 with a 0.3L larger displacement.
The LS2 is more similar to the LS6 than it is to the LS3, but there are some differences. Going from the LS6 to the LS2:
All-new aluminum block casting incorporates provisions for external knock sensors and revised oil galleries; external sensors improve serviceability
Cylinder bore diameter increased to 101.6 mm (4.00 inches), increasing displacement to 6.0 liters
Camshaft lift increased to take advantage of increased cylinder head flow
Camshaft sensor relocated from the rear of the block to the front of the block provides room for new oil galleries
Flat-top piston design with lower ring tension reduces friction
Piston floating wrist pins help quiet the engine
Redesigned, “wingless” oil pan with cast baffling has reduced mass and provides superior oil control under high-performance driving maneuvers
Revised exhaust manifolds are 33 percent lighter
More efficient ignition coils require less energy to provide a comparable spark
Compression raised to 10.9:1
Larger, 90-mm single-blade throttle body
Reduced-mass water pump design with improved sealing capability
Engine redline raised to 6500 rpm
Revised and more powerful engine controller incorporates all electronic throttle control functions.
__________________
Contact:
(e) zach@katechengines.com
Old Oct 11, 2008 | 01:16 PM
old motorhead's Avatar
old motorhead
That sums it up very well. You might add that the LS3 has offset intake rockers similar to the LS7. LS7 has 1.8 ratio vs the LS3's 1.7
