vararam vs. vortex rammer
and we ALL know what cooler air can do for IATs.
I'm sure they did do it more so for packaging, but isn't that the point of aerodynamics. To lower the wind resistance on the car, and more specifically the front of the car. And not to take away the fact that air flow past the car is important as well, but frontal area is a key measurement. And allowing plenty of air to get to the radiator is one of the key functions in keeping an engine running and they didn't have any problems putting it there since its like that on lots of cars. It's either that or have a big flat front end.
Even still most of the air that touches the condensor goes right on through it.
And the turns mean next to nothing as soon as it hits that wall (aka the filter). Pressurized air in front of the filter is pressurized air in front of the filter. I'm pretty sure it doesn't care how it gets there.
The only concern would be keeping that air pressure up. And on this I'll give one point to Vararam and one to Vortex. The Vortex has an abundance of air from the huge hole in front of the radiator and the air dam, scooping up even more, but it does have that big ol' box to fill up, which during a WOT pass may lower over PSI. Where as the Vararam doesn't have all that extra void to fill it could potentially sustain pressure better, but it just doesn't have the volume due to size and location of the entry that the Vortex does.
Either way I think those are moot point because the engine is breathing through a 4 inch hole (or less) and there is no way that it could use everybit of air the is going into either one.
There may be some science to prove or disprove what I've said, but that's just how I see it. Either way you have a good setup, theres just no reason to dis on or the other with out actual back to back comparisons of both. And saying "this car has it and it does this" isn't really that good of a comparison. If you didn't know.
but I suppose it's possible.If someone is so aloof and care free (aka: stupid) enough about their Corvette to go through water deep enough and fast enough to get it into their motor with a Vararam on the car then they're very likely to do the same damn thing with ANY cold air kit on there, Vortex included. Even the stock set up will allow enough water into the motor if an idiot driver barrels through a foot+ deep puddle at 30mph+.
If you also remember correctly, Dennis did in fact upgrade his Vararam along the way once or twice while helping them with some development/R&D, his current Vararam is not the same one that he had on the car when it was still in the high 11s, that unit is on my car now.
I've since reinstalled the Vararam because of the marked differance in performance from the stock intake in comparison. Now that I don't have to worry about severe weather popping up out of nowhere!
It's also at the top of the LS3 internal mods (Ed) and LS2 cam only (TonyB) lists as well.
