4 to 5 gear shift solution?
Old Oct 14, 2008 | 04:39 PM
autoxnut's Avatar
autoxnut
Default 4 to 5 gear shift solution?
There have been several threads posted on people experiencing difficulty in the 4th to 5th shift at high speed and high RPM. Most of the consensus has been driver excitability. However I seem to remember one reply that involved transmission work that solved the problem. It seems like someone posted about a shaft or shaft bearing that fixed the problem for them. I spent several hours searching the forum and could not find the correct thread that contained this reply. Can anyone help me? My transmission is presently being worked on and I want to make sure this is checked. Thanks in advance for the help.
Old Oct 14, 2008 | 05:16 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
was this the one you were looking for?
http://forums.corvetteforum.com/show...625&highlight=
Old Oct 15, 2008 | 10:53 AM
autoxnut's Avatar
autoxnut
Thanks for the reply. That is not the post I was remembering.
Old Oct 15, 2008 | 12:58 PM
LJD51's Avatar
LJD51
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
Are you using a stock shifter? I had the same problem until I had an MGW shifter installed last month.
Now I don't have any problems with hitting the correct gears.
Old Oct 15, 2008 | 06:52 PM
Dgatto's Avatar
Dgatto
I had the same issue, with 410 gears, I am hitting 5th much more often.....once I even hit reverse and fried the reverse gear...
I was thinking of going with an mgw, but wasnt convinced it would cure the problem....now I just make longer shifts into 5th...
To 4 to 5 gear shift solution?
