Installed the VMAX Ported Throttle Body tonight
After the install, I went out and tested it. I'm not sure if I can feel any sotp gain, as the likely 7-10hp on top of the ~436+ that's already there is not a large percentage
however, throttle response is improved, and there were absolutely no driveability issues.
I went out to the nearest freeway onramp and nailed it in first gear, and the car got SIDEWAYS before the traction control shut it down
I have not had the car do that before the throttle body install...so that was kinda cool. It's like the power just HITS, now.
If this part was $500, I'd say pass on it, but for $150, it's a solid mod
oh, and this is on my 08 c6 coupe, 6mn, with vararam & magnaflows
i'm not saying it'll be a problem, i just wonder why that used to be said and why it isn't an issue now
The piece you receive is not just the throttle body itself, but the entire unit that you just swap your electronics plug-harness into.
sorry to be so **** about this, but i feel the stock car is sooooo perfect to drive daily with a little tuning that anything that would introduce ANY negative drivability would be out for me
