2008 C6 Convertable Procharger Cooks 1-7/8 LT Headers Hi Flo Cats.
Having Problems With Wheel Hop 1st & 2nd Gear From 30 MPH In 1st And 40 MPH in 2nd. Any Sugestions Would Help.
Thanks for all the sugestions
From: Greater Detroit Metro MI, when I'm not travelling.
What tires and at what pressure?
I'm making 597whp/518wtq so wheelspin is guaranteed in 1st and 2nd and some times 3rd if the tires are cold (PS2 tires). Wheelhop, however, only happens sometimes and also seems to depend on tire temps as well. I am starting to wonder if some of what I think is wheelhop is actually the drivetrain bouncing on it's soft rubber mounts?
From: NJ..."the way I saw it, everyone takes a beating sometimes."
I recall hearing something about that myself. The "experts" agree that it is in fact a combination of several things; suspension geometry, shocks, tires/sidewalls, etc. I believe DTE mad a long thread a while ago outlining their believed causes of wheel hop and suggested fixes. I'll have to search for it.
I don't know if this was the exact post I was looking for but it contains good information non-the-less.
Originally Posted by DynoTech Engineering
The DTE Differential Strut was *never* designed to correct a axle-tramp condition, as that is a function of suspension/driveline wind-up and deflection, which entirely different altogether... The differential strut was however, designed to provide structural strength to a few targeted areas of the driveline, for which it does exceptionally well.
We've been preaching this before in *many* threads in the past- there is no silver-bullet, one-part-fixes-all component that will correct wheel hop, but rather a combination of a number of small, but critical upgrades that will eliminate it entirely....every time.
1. Coil over shocks with adjustable rebound/compression
2. Correct ride height
3. Correct dynamically adjusted wheel alignment
4. Correct tires (and no...."20's" will not cut it with that thin tire side wall...)
5. Correct tire pressure
6. Polyurethane suspension bushings
We've done all of the above to quite a few of the cars we build here that frequent the drag strips and not a single one of them ever has wheel hop again...ever. It takes a lot of work to perform all of this and it's not as glamorous as adding power, but fixing broken driveline parts over-and-over-and-over again due to wheel hop isn't fun/cheap either. Pick your poison..
Most folks never do all of the above at once, but rather try to cheap-out and only just do a couple of them to "save money" or because they "don't think they need to do anymore" than what they've done. Then those folks are always scratching their heads later when their car still wheel-hops anyway, or they say, "it only wheel-hops a little bit". *Any* car that wheel-hops, even a "little bit" is far too much, as it *will* fracture the driveline eventually...
The only way to secure driveline durability over time is to *completely* eliminate wheel-hop altogether. There are no "gray areas" and even a "little" is too much.....
In the ZR1 GM installed different diameter axles for the left and right sides to eliminate wheel hop. I guess the jury is still out on that but I'm sure it worked.
This is a thread that I started in the C6Z section about the Zr1 shafts before I knew about the differences. I just wanted to see if they were the same size as the z06 but stronger so I could swap them out if I wanted to. Some posts in it explain the reason for the different diameters.
This may be a cheap way out When was the last time your car had
a 4 wheel alignment???
alot of times even from the factory they are way off.
Mine was a complete disaster. Zero wheel hop after the alignment.
I lowered the the car too. With the power you have you should be driving around with DRs all the time. That alone will cure wheel hop
Mike
[QUOTE=walterm32;1567515418]In the ZR1 GM installed different diameter axles for the left and right sides to eliminate wheel hop. ...QUOTE]Yes, BUT they ALSO wrote a program for the rear end to "squat" on WOT with the magnetic shocks.
