need help with shocks asap!
Old Oct 26, 2008 | 12:17 PM
james1990's Avatar
james1990
Default need help with shocks asap!
hey guys,
i am having my rear w/b kit put on this weekend, getting zo6 repos with 345's in the rear, and my calipers painted..while its in the shop i decided to eaither lower the car, or do shocks, or coilovers
i do not know much about doing this so which is the best to do in the ballpark of 1,000? which is the best for proformance? and lastley, what brand is the best?
i have one day to decide on this so any help is great
Old Oct 26, 2008 | 01:18 PM
AirBusPilot's Avatar
AirBusPilot
With a $1000 budget you can't afford coil overs. That leaves regular shocks. I know of two, Koni's and PFADT (adjustable). Koni's are a little cheaper, but the best deal I've seen is low $600. The PFADT's are almost $900 if I recall. You won't go wrong with either.
Old Oct 26, 2008 | 04:58 PM
timd38's Avatar
timd38
I did Bilsteins yesterday. About $350, plus labor. I did it myself in a couple of hours and a bottle of wine,
Old Oct 26, 2008 | 05:29 PM
james1990's Avatar
james1990
what is the difference between shocks and coilovers? if i do shocks and save up for coilovers would i need to replace the shocks? or can i always add the coilovers to the shocks?
my goal here is to lower the car, and im trying to see if i can add proformance by doing this and how much more will it cost me because i could always just use lowering bolts
Old Oct 26, 2008 | 05:53 PM
bosco 08's Avatar
bosco 08
how are they?
Old Oct 26, 2008 | 06:38 PM
Swiftrider08's Avatar
Swiftrider08
Just shocks will still use the already installed transverse leaf springs front and rear. With coilovers, these leaf springs will need to come out. Coilover shocks are an assembly with the shock and spring built together. You can not buy new shocks and then just add the coils later. They are not made that way. I think the coilovers will cost you around $1600 and then there is the labor to install and remove the leaf springs, if you are not doing the work yourself.
If your only real goal is to just lower the car, I would lower the stock bolts first and see if you get the look you are after. If not, you can then go to aftermarket bolts.
Old Oct 26, 2008 | 06:41 PM
timd38's Avatar
timd38
Originally Posted by bosco 08
how are they?
A little stiffer, but I like the ride.
Old Oct 26, 2008 | 06:47 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Just think what it will be like with snow tires. LOL
Old Oct 26, 2008 | 06:49 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
There are coilovers that are designed to work with the leaf springs. Eibach/Callaways come to mind.
San
timafey's Avatar
timafey
Did your Bilstein shocks help with wheel hop? That would be my main goal in changing the suspension.
Old Oct 26, 2008 | 06:51 PM
timd38's Avatar
timd38
Don't know but others say they do.
Old Oct 26, 2008 | 06:54 PM
timafey's Avatar
timafey
I think for the sake of the CF community you will have to go out and dump the clutch at 4k rpm to see what happens and report here with your finding on that wheel hop
Old Oct 26, 2008 | 06:56 PM
timd38's Avatar
timd38
To late. That car is back in the garage with the tires off. I bought a set of BBS Wheels and plan to have the tires mounted this week on them.
Old Oct 29, 2008 | 08:15 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
The best bang for your buck are the 2008 Z06 shocks for around $250.
Old Oct 29, 2008 | 10:01 PM
AirBusPilot
What is so special about them? Gas charged?
Old Oct 30, 2008 | 01:04 AM
bosco 08's Avatar
bosco 08
$250.00 vs much more $
To need help with shocks asap!
