procharger
Old Oct 30, 2008 | 08:34 PM
bigdan3419's Avatar
bigdan3419
Default procharger
have a 08 and just got a price of 7200 to install a procharger,is this the way to go for more power,thanks for any advise.
Old Oct 30, 2008 | 09:04 PM
GForceSS's Avatar
GForceSS
Not sure you will get many replies to that in this section since this is the 09+ ZR1 section. Depending on which model Vette you have i would move it to that thread. Regarding the subject, Procharger is a great brand and it will most definitely add a good amount of power to either a Z06 or LS3 Vette. Check the FI section for more help and answers.
Old Oct 31, 2008 | 07:14 AM
tloon's Avatar
tloon
09 plus ZR1?. This is Tech / Performance
Old Oct 31, 2008 | 08:50 AM
theofel's Avatar
theofel
St. Jude Donor '10-'13
Great price! MAKES PLENTY OF POWER. I would also do all the standard stuff that will allow your engine to breath. (160 thermostat, Lt headers, flow thru cats, big sticky tires and a good tune).
Old Oct 31, 2008 | 12:50 PM
goatts's Avatar
goatts
It's one way. You could go NA with heads, cam etc. But make sure whoever does it knows what they are doing. Don't be surprised if you start having problems after you mod the car like this.
Old Oct 31, 2008 | 12:54 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
The Vette Doctors charge about $900 less for the A&A Vortech kit installed, which is, IMO, a better kit... I'd go that route if I were you; they are within driving distance...
Old Nov 1, 2008 | 01:04 AM
Deceptikon's Avatar
Deceptikon
Sounds like a good price. I hope it includes an intercooler and new injectors. You may also need a degree colder spark plugs, but don't quote me on that.
Old Nov 1, 2008 | 01:06 AM
Deceptikon's Avatar
Deceptikon
OOPS, duplicated my post
Old Nov 1, 2008 | 01:16 AM
3 Z06ZR1's Avatar
3 Z06ZR1
[QUOTE=GForceSS;1567670571]Not sure you will get many replies to that in this section since this is the 09+ ZR1 section.* QUOTE]had me fooled thought it was the tech section!* Get the A&A set upinstalled for that price. !
Old Nov 1, 2008 | 08:04 AM
R50THC5's Avatar
R50THC5
ECS has a great package in Jersey . I put a P-1 on my 06A6 Aug 2007 fm EPP (Indiana) In retrospect I have seen high 400/low 500 rwhp with heads cam and headers cat back etc...Because of the changing oil in the head unit, I sorta wish thats the way I went. However, very happy with my 471rwhp 445 rwtq. Did not want to over power the stock drive train. Limited budget also. Good Luck which ever way you go.
Old Nov 1, 2008 | 12:31 PM
thomas walters's Avatar
thomas walters
Many Forum members feel that A&A has a better kit. Call Andy @ A&A. Hard to go wrong with A&A products.
Old Nov 1, 2008 | 12:37 PM
Jupiter38's Avatar
Jupiter38
It's a great way to go, make sure you get the one made for the LS3
I have a 2008 I just modified
Procharger, long tubed headers, Corsa exhaust
About 650 + HP but we limited the amount I put on the rear wheel to about 550
This was not b/c of the trans but the differential ,
I try to keep it to 5500 rpm's in every gear
The paddle shift is protective and suits the HP very well
no problems yet, she's king of the road, low tens 1/4 mile, totally stealth
She's my poor mans ZR1
Old Nov 3, 2008 | 08:28 PM
GForceSS's Avatar
GForceSS
This was originally posted in the ZR1 section, it has since been moved after my post. Why else would i point out 09 (rather than 08 ZR1; doesnt exist). Then nicely suggest moving it to a place where the OP could get the most feedback. Go look for yourself in the ZR1 section, and it doesnt require any smart@ss comments to do it
Old Nov 3, 2008 | 08:44 PM
7RED's Avatar
7RED
Do some homework, and be sure to check out A&A
Old Nov 3, 2008 | 08:45 PM
NYC6's Avatar
NYC6
Erie,Pa to Amityville,New York is theoretically driving distance but so is LA to Miami.
Old Jan 27, 2009 | 12:30 PM
woodshark's Avatar
woodshark
I installed the procharger kit myself, and could not be happier. I like the procharger over the vortec, cause the procharger has it's own oiling system. On the vortec you have to tap into you engines oiling system, and drill your oil pan for a return line. The procharger kit came with new injectors, intercooler and they reprogramed my computer as part of the deal. I took the car to the dyno after the install and found the A/F mixture to be right on the money. With a little more tweeaking on the dyno we were able to get 560 rwhp. out of this combo. If you take your time you can install it yourself with a little effort. Pinning the crank is the hardest part of the installation.
Woodie
Old Jan 27, 2009 | 01:42 PM
Jutskin's Avatar
Jutskin
Woodie
You have helped me to decide on a procharger...appears to be same package from procharger. thanx.
Been mulling it over for weeks.
12.0's last year, hopefully into the ten's this year.
To procharger
Old Jan 27, 2009 | 02:40 PM
NYC6's Avatar
NYC6
After alot of research I went with Vortech. I upgraded to the T trim for an additional $150. Complete kit installed with ram air intercooler, plugs, 60 lb injectors, boost a pump, tuning and before and after dyno for $6800. A couple days later I picked up a Z06 killer.
Old Jan 27, 2009 | 04:01 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Woodie
The Vortech and Paxton both have self-contained units!
I have the self contained self installed V-3 T-trim that came with my A&A kit!
Old Jan 27, 2009 | 05:11 PM
CPG1962's Avatar
CPG1962
St. Jude Donor '09-'10
100% - This is very good/sound advice - why not a blower cam while your at it
