Long Tube Headers on C6
Old Nov 4, 2008 | 04:40 PM
jpee's Avatar
jpee
Default Long Tube Headers on C6
I was at my local Chevy dealership, and was talking about how I race my car etc.. (The Service Mgr also Drag Races & THATS GOOD I always get him a Christmas gift, and it has been one of my better decesions... I've come out WELL Ahead..
Anyway he told me that a lot of people, or Manufactures of headers are having a problem when installing "Long Tube" headers the C6's are throwing a code... ? Thats what he said he's heard, in-fact he said Lingerfelter has gone to short headers...
Anyone here anything on this... I'm just guessing but if you did have long tube, and had high flow cats, and the air sensors where they belong (before & after the cat.. the car shouldn't throw any code. but he said he heard they were.. ???
Old Nov 4, 2008 | 04:46 PM
Bad06vette's Avatar
Bad06vette
Just tune it out... solves the problem.
I have not had any codes or problems with my headers. I run the LG Pro Lt's.
Old Nov 4, 2008 | 04:59 PM
JayplaySS2's Avatar
JayplaySS2
The tune fixes each long tube header 02 code
Old Nov 4, 2008 | 05:01 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Long Tubes move the cat farther away from the engine, which takes them longer to get hot, and sometimes trigger the CEL. A handheld or computer tune will turn it off. "Shorty" headers are not worth the money as they only gain about 8 HP.
Old Nov 4, 2008 | 06:37 PM
MLCZ51's Avatar
MLCZ51
Default I agree.. I have had both..
Old Nov 4, 2008 | 06:50 PM
MARSC6's Avatar
MARSC6
Never had a problem. Using dynatech for 1 1/2yrs.
Old Nov 4, 2008 | 07:13 PM
nwc6's Avatar
nwc6
A lot of installed don't set the code right away. It can be weeks before the right factors all fall into place. The code is usually for the cats not reaching temp in time..Tune them out, no issues.
Old Nov 4, 2008 | 08:14 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Old Nov 4, 2008 | 09:15 PM
cmonkey713's Avatar
cmonkey713
Me too! No problems with mine.
Old Nov 4, 2008 | 10:41 PM
Wayne O's Avatar
Wayne O
CF Senior Member
To the best of my knowledge Lingenfelter has not "gone" to shorty headers. LPE has never installed long tube headers on a car due to potential legal issues. They will, however, work on your car if it comes in with long tubes already installed.
I know one tuner shop in California that will install long tube headers if you sign a waiver that your car is strictly for off-road use and they have to physically witness your car being towed or hauled off property after the install.
FWIW, I've had LG Pro long tubes (coated) with high-flow cats for 2.5 years....I've never had a problem or thrown any codes.
Old Nov 5, 2008 | 10:19 AM
jmt1669's Avatar
jmt1669
St. Jude Donor '11
I installed my Kooks two weeks ago and have had no code problems.
Old Nov 5, 2008 | 11:22 AM
Poppy's Vette's Avatar
Poppy's Vette
Just goes to show how different the same can be! Did your headers come as part of the Lingenfelter package? Did it come with a tune all at the same time? If so, I suspect you never saw a code because it was tuned out before you ever saw them. How else would we explain such differences in the same basic setup and one car throws codes and another doesn't? I always find this an interesting discussion. Not because we learn anything but because there is such a variety of experiences.
I have the LG Pro long tubes and I had trouble codes almost instantly. They were "tuned out" by my tuner though. Unlike most people I have read, I had codes for both sets of cats.
Old Nov 5, 2008 | 11:45 AM
xkilo16x's Avatar
xkilo16x
My Kooks 1 7/8" w/o cats through a CEL. Obviously
I had ECS tune that out when I got my tune. Its pretty normal. Most long tubes are not emissions legal anyway.
Old Nov 5, 2008 | 11:48 AM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Me too (Kooks 2 weeks ago), but according to an earlier post, we should not be fat dumb and happy yet - it may take a while for us to see codes, if we are gonna.
Old Nov 5, 2008 | 11:56 AM
Vito.A's Avatar
Vito.A
Default O2 Sensor codes with long tube headers
Chevy uses a dual O2 sensor system on each side to test the Cats. The front O2 sensor inputs AFR changes and the rear should be flat as the CATS burn any excess fuel. However, for the Cats to light off, they must reach a very high temperature. You will recall that C4 vettes have a single Cat that is halfway down the exhaust pipe and only one O2 sensor, whereas C6 cars have the Cats up front bolted directly to the cast iron exhaust manifolds. This is so they heat up almost immediately after startup.
Now, you install long tube headers and a hi-flow X pipe and the Cats are down wind a lot further and it takes them longer to fire up. The second O2 sensor output is not flat when this happens and this sets a P0430 or P0420 code meaning the Cats are not working. The car will still run fine, you will just be staring at the check engine light periodically.
Most tuners can tune out the rear O2 sensor or supress the Cat codes. You can also do this yourself with a hand held Predator.
Old Nov 5, 2008 | 05:36 PM
Stage IT's Avatar
Stage IT
rule of thum dont listen to anything someone in a Dealer service department says about aftermarket stuff. When ever you change something about the cats on a new car (aka hiflow or none)there a parameters that need to bee adjusted in the computer and you will get a light with them untill you do.
To Long Tube Headers on C6
