SPINFAST install with pics
Old Nov 10, 2008 | 08:57 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
CL mod
Old Nov 11, 2008 | 06:22 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by Isaiah48
Take a look at your Power Enrichment to clear up the spark knock at the 4000 up rpm range, the fast will make it go lean since that's the area where the intake really starts to give a lot more air flow over the stock unit. If you had a wide-band hooked up, I'd bet your'e going as lean as 14.0-16.0 under wide open throttle causing it to go lean and henceforth KNOCK! Big cams and big free flowing intake tracts love fuel... Mine likes it around 12.9 under WOT
Isaiah I've got a WB and it was running around 13.3 with my pre-fast fueling, but your estimation once again is on point - my best results were 12.9 -12.7 on the dyno. When I hit the track that may lean out some so I'll keep my eye on my WB scans. I also programmed the Warmup Transient Fuel change you recommended, we'll see how that combined with the increased timing down low < 3k does around town with increasing the engine response for heel and toe shifting.
Question for you (and others)...I noticed that my Dynamic ClyAir (load on the engine) was .82 at tq peak of 5k, trending down to .76 on the top end at 6.7k. MAP was consistent at 100. My initial though was perhaps my vararam or MAF screen were causing a restriction at my new power level (or my air filter might be dirty), though the MAP remaining consistent countered that theory. Dyno operator thought this is due to the fact it was an inertia dyno and the load on the engine gets less as rpm's go up.
Any thoughts?
Old Nov 11, 2008 | 03:00 PM
Isaiah48's Avatar
Isaiah48
Any thoughts?
Well your A/F wasn't out as far as I thought it might be, but enough to make some possible spark knock, I'm not sure why you had to take out so much timing even after you got the A/f right though, 1-2 maybe, but 3-4 might be overkill or just very safety consious... As far as the Warmup Transient fuel change goes; if you go too far your rpm's wont drop as quick in between shifts, so it's a fine line. 10 was stock and 15 was too far. As far as the Dynamic Cyl Air goes, I haven't setup a pid for that yet so I'm not exactly sure what to think although what dyno operator says would definitly makes sense. It would have to factor into the total load.
I'm not sure if you remember talking with me over the phone last year but the advise you gave me as far as launching goes has been a great help, I'm consistently pulling high 1.6's to low 1.7's. Not sure how many more runs my clutch and dr's have in them though. Now I just need to get me a FAST so I can go really fassstttt.
Old Nov 11, 2008 | 08:14 PM
bunk22's Avatar
bunk22
Nice gains. Our graphs from 3500 on up are very similar, almost identical at points. Below 3500, due to that bump in compression ratio, you've got 20-30ft-lbs on me. Of course those 3.90 gears probably lower the numbers just bit?
Old Nov 11, 2008 | 10:43 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Well, some say the 3.90's are around 10 rwhp/tq up top due to the inertia dyno. It was a different dyno, but overall that shows that the dynos are comparable on how cose my runs were down low on each dyno.
The compression bump is a good mod and not so expensive.
If you've got your .drf files from your dyno I'll overlay our graphs so we can see how they look so we can see what the compression would do.
Old Nov 11, 2008 | 10:47 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Hey glad to help!! These ls2 clutches are amazing. I've got 250 runs on mine and it keeps on ticking and taking me to and from work every day. Like you, my DR's are getting thin so I'm buying some new ones to go with our new 1/4 mile concrete track, Palm Beach International.
Old Nov 12, 2008 | 12:02 AM
SpinMonster's Avatar
SpinMonster
Since you have 3.90's, you're pretty close to a cam only 460rwhp. AFR's would make for a quick 40 more.
Old Nov 15, 2008 | 09:32 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
My beloved cutouts still add the same 6 rwhp across the board that they added without the FAST as shown below.
Old Nov 15, 2008 | 09:46 AM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Joe G,
Quick question....Did you have your stock LS2 intake ported before you got the Spin Fast90?
Old Nov 15, 2008 | 09:49 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by Tony B4
Joe G,
I sure did. Gave me about 10 rwhp. Cory Harris of ls2portworks.com did it, and it was a GREAT bargain for the gain...10 rwhp for $225 vs 14 for my $1,300 FAST....lol
But the FAST was the next step in my progression. Heads & clutch will be next.
Old Nov 15, 2008 | 09:55 AM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
So the ported Fast90 gave you 14rwhp over the ported Stock intake?
What would be the total gained with the Fast90 over the stock unit?
Old Nov 15, 2008 | 12:09 PM
BOB EAGAN's Avatar
BOB EAGAN
Ported stock will give 10-15 hp. I believe Spins last post showed 27 RWHP and 32? RWTQ gain from a ported Fast compared to stock.
Old Nov 15, 2008 | 12:34 PM
  #33
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I got about 10/10 from the ported stocker...and 14/15 from the Spinfast.
So 24/25 from stock to ported Spinfast.
I'm eager to get some 1/4 mile times, our first Corvette Challenge on the new track is next week. The weather is still hot though...I'm on my back porch sweating at 86 degrees as I type this!
Old Nov 15, 2008 | 12:57 PM
  #34
Black02SS's Avatar
Black02SS
I figured I would chime in here and see what others thought. My setup and Joe's are almost identical. The only differences are intake (90/92), gears (3.42/3.90), and compression (MLS/.040). Below is a graph of my car vs. Joe's. (435/443). Obviously there are variables in dyno's, but we are looking at around a 8hp difference between the two cars. SPIN says remove ~10 for the gears and add ~7 for a (-3hp) calculation on this. This brings our difference to 5hp. Only reason I bring this up is I feel it is a good calculation to use and have the graphs to show.
Also, my MPH in the 1/8th is ~95mph.
Joe - Where is your cutout located?
Old Nov 15, 2008 | 01:10 PM
  #35
Joe_G's Avatar
Joe_G
St. Jude Donor '08
My cutouts are at the point where the midpipes meet the over axle pipes.
Do you have to shift to 4th in the 1/8th?
Here's a pic.
Old Nov 15, 2008 | 01:19 PM
  #36
Black02SS's Avatar
Black02SS
Nope. But 3.90's will soon be on my list of mods. Remember I am using the stock tires when I head to the track too. The car only runs 12.2@122, but with a 60' of 2.1 in +2500DA.
Old Nov 15, 2008 | 01:29 PM
  #37
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I went to my 1/8 mile track the other day with street tires...ran a 2.3 and 7.9 and got my a$$ handed to me by some dude in a SRT8 Dodge 4x4 SUV who ran a 1.6 and 7.4. (thought I heard later he was running a sneaky pete nitrous system).... I can't stand running street tires!
To SPINFAST install with pics
Old Nov 15, 2008 | 07:39 PM
  #38
pmj341's Avatar
pmj341
Here's a pic.
Joe
Who did your cutouts??they look good!!!!!!
Old Nov 16, 2008 | 09:50 PM
  #39
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by pmj341
Joe
Thanks! Rob at Florida Performance at Dixie and Commercial down here. Here's more details including install tips.
http://forums.corvetteforum.com/c6-t...-on-my-c6.html
Old Dec 1, 2008 | 09:49 PM
  #40
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Default Props for SPINMONSTER
While I didn't gain as big of "under the curve" as some people did, the REAL dyno, the dragstrip, shows what my SOTP meter is feeling. My car is a LOT faster.
I am now trapping 124 consistently in the 1/4 and 95+ in the 1/8. I used to trap 120 consistently and 93 so it's a solid 4mph and 2mph respectively. My buddy who I used run neck and neck with I now can whoop in a 4th gear roll on the track.
Here's a thread on my recent track results.
http://forums.corvetteforum.com/c6-t...with-pics.html
And video
