Steering wheel vibration, wtf?
A litte back ground. I purchased some CCW 505a wheels used and put the tires off of my stock wheels on them. One of the wheels was slightly bent. I had it sent off to be fixed. Upon recieving it back, it balanced perfectly. According to my tire shop, all of my wheels balanced perfectly.
I thought it may have been the alignment as I lowered the car before putting the new wheels on. I went and had it aligned about a week ago. The alignment did nothing to fix the vibration and neither did fixing the slightly bent wheel.
What could cause a vibration at only 65mph+ that cycles "on" and "off" every ~10 seconds?
I think you have one or more bad tires or wheels.
However, it's something to check out.
The rotor is held on by the brake caliper and the wheel. When the car comes down the assembly line, they stick a rotor on the hub and it would fall right off until they mount a caliper and finally a wheel. Take a look at the picture below (I lifted it from sperkins cracked rotor thread in another section):
In the picture above you can see 2 "Tinnerman Nuts" on 2 of the lugs - those are put on when the rotor is installed on the assembly line and they hold the rotor on until more parts get installed.
Some aftermarket wheels do not have countersunk areas around the holes for the lugs and the Tinnerman Nuts will not allow the inside face of the wheel to mount flush and flat with the hub.
What you are experiencing sounds similar to the vibrations that people get when they put aftermarket wheels on without removing those nuts.
Those Tinnerman Nuts are not needed at all. I recommend you remove them to make sure they aren't interfering with a flush fit of your wheels on the hub. I'd also take a wire brush to the hub and clean off any corrosion that might be messing up a flush fit. Check the inside of your wheels for any corrosion as well.
So....the CCW's should have countersunk areas for the Tinnermans, but I'd remove those nuts anyway and clean up the whole area for a nice flush/flat/square fit of wheels against the hubs.
Good luck!
Bob
The dealership could use the electronic vibration analyzer (EVA) tool to help isolate the cause of the vibration.
The alignment is still a remote possibility. I had an alignment not too long ago but after cording my front tires on the track, some knowledgeable racers I know suggested I go to my local Volvo dealer for an alignment. Evidently, Volvo just got new, high-tech laser alignment equipment that is supposedly the best going. I don't know much about it yet but I'm going there next week after I change my suspension. You might want to verify your alignment. Good luck!
with WayneI threw out the sheet-metal rotor retention nut thingy as one of the possibilities. It's pretty easy to check, and it would be nice if were something nice and easy like that!!!
Let us know what you find out.
Bob
/thread
a tire can balance but still be seperated and give you a shimmy. You need to check the front tire and rims not only for balance but for lateral runnout,,,if you throw a tire on a balancer its usually pretty easy to look at it spin and see whats causing the vibration. More then likely i would say you have a bad tire either sperated, out of balance, or wearing funny causing your shimmy. look there before looking into wheels, bearings, mounts etc.. good luck paul
. The wheel is absolutely rock solid now. I took those little suckers off of all the hubs. I admit, I was skeptical, but it completely fixed the issue. Thanks again for the help everyone
I was skeptical too. I was hoping it might be something simple like that, but I really thought it might be that wheel that had been repaired.
Glad we could help!!
Bob
