Bilstein Spts front top mount
Old Nov 30, 2008 | 01:15 PM
drivinfast's Avatar
drivinfast
Default Bilstein Spts front top mount
I have had these shocks all around for about a year and a half and every so often the top mount needs re-tightening so there is no thunk while turning slow on or off an incline.
I used the new bushings and lock nut on install. After that I loosened them to install aftermarket lowering bolts.
Should I have used a new lock nut at that time so it will stay tight? Or could the bushings just be getting worn and the nut needs to be tightened from time to time?
Old Nov 30, 2008 | 03:11 PM
99FewteRC5's Avatar
99FewteRC5
you can put another nut on top of the first nut..that will lock it place
Old Nov 30, 2008 | 05:06 PM
danl72's Avatar
danl72
That's an idea.
Old Nov 30, 2008 | 05:16 PM
timd38's Avatar
timd38
Just go to the local hardware store and get a jam nut that is the right size.
To Bilstein Spts front top mount
