Bad WOT valve chatter
Old Dec 3, 2008 | 06:23 PM
mecomp1's Avatar
mecomp1
Default Bad WOT valve chatter
been getting an awful lot of valve chatter @ WOT the past few weeks (and a noticeable loss of power). I am assuming this is a timing issue and would like some opinions on wether or not I should have the stealership do a diagnosis or just go to a good tuner? I know nothing about tuning by the way, just what I have read here....thanks for the help!
Old Dec 3, 2008 | 09:02 PM
HawaiiC6's Avatar
HawaiiC6
If your vehicle is under warranty take it to the dealer
Old Dec 3, 2008 | 09:19 PM
calemasters's Avatar
calemasters
Are you sure it is valve noise and not pre-detonation or spark knock?
Most valve noise on the LS2, LS3 is at idle, not WOT.
If it could be pre-detonation, you could try some octane booster or maybe buy a higher octane fuel for diagnosis.
Old Dec 3, 2008 | 09:41 PM
07MontRedcp's Avatar
07MontRedcp
My thoughts exactly.
BJK
Old Dec 4, 2008 | 07:52 AM
mecomp1's Avatar
mecomp1
I'm fairly sure its valve chatter, only occurs at WOT and it seems as if the car is not advancing the timing when I stomp on it (assuming the C6's do this). I think i;m going to take it in since its under warranty and see if the dealer can diagnose the issue. I just hate going to those guys because it seeems like they blow off any warranty work adn try to stick me with something not under warranty. You know the drill......
Old Dec 4, 2008 | 08:42 AM
MattsVette02's Avatar
MattsVette02
When I bought my car, it had bad gas in it and made this noise... get some octane booster like the guys above said and you'll be a happy camper! I drove mile till it was getting empty, and then filled her up with the good stuff
To Bad WOT valve chatter
