How to clean vararam ??
Old Dec 4, 2008 | 07:17 PM
warlok's Avatar
warlok
Default How to clean vararam ??
As far as i know the air filter is reusable, right??If so, what do you use to clean it, if not, what type of replacement filter?? Thanks
Old Dec 4, 2008 | 07:50 PM
c6-pwr's Avatar
c6-pwr
Fill your sink with water, add a tad of dish soap, swish the filter around, rinse the filter in clean water, let dry
Old Dec 5, 2008 | 12:06 AM
warlok's Avatar
warlok
you dont use any oil or anything??
Old Dec 5, 2008 | 01:16 AM
c6 batmobile's Avatar
c6 batmobile
You can clean it with a K&N recharge kit. The solvent gets the old oil and dirt out and then you re oil it. dont over oil it though as it can create some problems.
Old Dec 5, 2008 | 06:55 AM
BlackZ51Vett's Avatar
BlackZ51Vett
You can either use a filter recharging kit (K&N or other), or you can clean it in warm soapy water. Let it dry naturally (dont take you air compressor to it ). Re-oil it lightly. Too much oil is not good for your MAF. The instructions on the K&N recharge kit are quiet good.......
To How to clean vararam ??
