Super Chip question....
Old Dec 4, 2008 | 08:38 PM
Big Chevy Man's Avatar
Big Chevy Man
Default Super Chip question....
I have an 08 LS3 motor, stick, somebody suggested using a super chip. Jegs does not have one for 08 - any suggestions?
Thanks.
Old Dec 4, 2008 | 09:36 PM
haljensen's Avatar
haljensen
There are no "chips" for the LS3 (or LS2) the only performance tune you can do is to modify the ECM. Lots of Tuners are doing the ECM mods, pick a local one or do a mail order tune.
From previous posts; You lose your GM Warranty when the ECM is modified.
Old Dec 4, 2008 | 09:40 PM
Swiftrider08's Avatar
Swiftrider08
PCM, not ECM. Other poster is correct as there have not been "chips" used in most vehicles for the last several years. You need a hand held tuner ($300-$600) or a tuner shop to do the tune for you.
Also as stated, no more GM warranty after a tune. If that matters. There might not be much of a warranty for any GM vehicle here pretty soon anyway.
Old Dec 4, 2008 | 09:41 PM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
What are you trying to do to the car?
Old Dec 4, 2008 | 10:02 PM
haljensen's Avatar
haljensen
ECM is correct; Engine Control Module. The Transmission ECM is separate on the C6
PCM is Powertrain Control Module, engine and trans combined in one Module.
Old Dec 5, 2008 | 07:42 AM
Swiftrider08
There is NO ECM. Engine is controlled by the PCM. See the following link and tell me where you see ECM anywhere? You won't.
http://forums.corvetteforum.com/c6-c...ial-hurry.html
The automatic transmission is controlled by the TCM (transmission control module) which is mounted next to the PCM on the 05 C6 models and is internal to the transmission on the 06's & up.
Old Dec 5, 2008 | 10:18 AM
haljensen's Avatar
haljensen
PCM = Powertrain control module. Powertrain is Engine and Transmission so a PCM controls both.
Your statement and link above show separate modules for the Engine (ECM) and Transmission (TCM).
The C6 has separate ECM and TCM, NOT A PCM.
Old Dec 5, 2008 | 10:57 AM
fastskyline's Avatar
fastskyline
yea but wheres the BQF???
Old Dec 5, 2008 | 07:29 PM
Swiftrider08
You are just simply wrong and don't want to admitt to that. Your even lost in your own words.
Yes, I agree there is a seperate TCM. External on the 05 C6 and internal to the tranny on 06 and up C6's.
No where in the link I posted does it say ECM, it only says PCM. I have the GM C6 Service Manuals right in front of me and no where does it say ECM, only PCM.
Go to Gene Culleys website at www.gmpartshouse.com and look up 08 Corvette parts. Type in ECM in the search bar an nothing will be found. Type in PCM and there you go!
http://www.gmpartshouseusa.com/partl...layCatalogid=0
You even say in your first sentence that the PCM controls the engine, so why do you keep saying it is controlled by the ECM?
There where ECM's in cars many years ago, but no longer. Those functions have been integrated into the PCM.
When you do a tune, you are making changes to the PCM for the engine and the TCM for the tranny.
No ECM !!!!!!!!!!!!!!!!!!!!!
Old Dec 6, 2008 | 10:17 AM
haljensen's Avatar
haljensen
My first sentence says Engine PLUS Transmission = Powertrain. Engine and Transmission controls in ONE module = a PCM. A PCM controls BOTH in one Module.
The C6 has TWO separate Modules, an ECM for the Engine and a TCM for the Transmission.
Older cars had PCM's, My '03 SRT4 had a PCM, engine and tranny controls were in one module, my C6 has an ECM AND a TCM. (And a BCM also but who's counting).
Old Dec 6, 2008 | 11:46 AM
dkrhardy's Avatar
dkrhardy
The referral to a super chip MIGHT be about the SuperChip company. I have a SuperChip tuner for my 300C, and when I asked them if they will make one for the 'vette, they said no plans to do so. It is a hand held unit that plugs in to retune.
Old Dec 7, 2008 | 06:44 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
I do not want to hijack this thread but would like clarification on the PCM/ECM debate (maybe in another therad). The P series codes only make reference to ECM and TCM, but there are also references to PCM in the code list such as C0240.
Old Dec 7, 2008 | 08:56 PM
haljensen's Avatar
haljensen
Swiftrider08; You seem to trust Chuck of Corvettes of Westchester so check his post #7 on 9-6-07 @ 10:04AM.
I can't find a way to link the post so you'll have to search it yourself. He clearly states ECM vs PCM in this post.
Old Dec 7, 2008 | 09:43 PM
BOB EAGAN's Avatar
BOB EAGAN
Is one claim correct and the other not? Are both claims correct? Are both claims incorrect? I have an 07 m6 and when my tuner did a dyno tune(for h/c package) what did he plug the laptop into to make program change? Pcm, ecm???
Old Dec 8, 2008 | 09:14 AM
haljensen's Avatar
haljensen
He probably plugged into the OBD2 port to access the ECM and if your car is an automatic the same port gives the tuner access to the TCM.
Old Dec 8, 2008 | 09:30 AM
BOB EAGAN's Avatar
BOB EAGAN
As stated I have an 07 m6. Thanks for the response.
Old Dec 8, 2008 | 10:12 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I recall Shopdog (whose mechanical knowledge I respect) once saying there is no "PCM" in the C6. My service manuals list an ECM in the index but not a PCM. There are, however, several references to a PCM within the service manuals. I've seen other GM references to a PCM as well. I believe for the most part, the PCM functions are controlled from within the ECM. My racer friend used to have a locked tune. Whenever adjustments were required, he removed the ECM (not a PCM) and sent it via overnight air back to the tuner.
Although there is no PCM per se in the C6, the term PCM is still referred to as if it was a separate, physical unit.
To Super Chip question....
Old Dec 8, 2008 | 03:17 PM
BOB EAGAN's Avatar
BOB EAGAN
This could explain all the confusion. Thanks for the writeup.
Old Dec 8, 2008 | 05:40 PM
Swiftrider08
Hey my friend, never intended to get into the battle of words we seemed to have been going through. Have not posted again as it really is not a big deal though it does seem that GM, and others, use both terms to talk about the same thing.
Just for future reference, to post a link, just left click on what is in the address bar to highlite it and then right click and hit copy. Go to where you want to post the link and left click, then right click and hit paste. Maybe you already know how to do that, but just in case.
Old Dec 12, 2008 | 01:56 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Here's the deal.....
ECM stands for "ENGINE CONTROL MODULE".
PCM stands for "POWERTRAIN CONTROL MODULE".
TCM stands for "TRANSMISSION CONTROL MODULE"
BCM stands for "BODY CONTROL MODULE".
EBCM stands for "ELECTRONIC BRAKE CONTROL MODULE".
IPC stands for "INSTRUMENT PANEL CLUSTER or CONSOLE".
Most new cars like the corvette have an ECM as the trans controller is not part of the same unit.
C5 corvettes with automatic transmissions use a PCM as the transmission controller is integral with the engine controller.
But, it's hardly a point to waste time arguing.
Not much different than "You say POTATO...WE SAY PO-TA-TOE".
Either way you say it, it still means the same thing.
Have a look at this thread. It will show some of the different units.
http://forums.corvetteforum.com/c6-z...chuck-cow.html
Chuck CoW
