Ceramic pad install
Old Dec 6, 2008 | 12:47 PM
Neil Baker's Avatar
Neil Baker
Default Ceramic pad install
Just purchased ceramic pads for my Z51. Any secrets or suggestions that would make the install perfect? Not the first time I've done brakes but I'm always ready to learn something new.
Old Dec 6, 2008 | 01:24 PM
BEZ06's Avatar
BEZ06
You've got 2 options: take off the entire caliper by removing the 2 large bolts that hold it on; or remove the pin the the caliper slides on.
Removing the pin is probably much easier. Here's a good thread with some pics:
http://forums.corvetteforum.com/c6-c...-calipers.html
Bob
Old Dec 6, 2008 | 01:29 PM
c6 batmobile's Avatar
c6 batmobile
I took the bolts out. It wasnt that bad. Just make sure you put some blue locktite on them when you put em back in.
Old Dec 6, 2008 | 01:33 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Take the pins off; it is much easier than getting the entire caliper off!
Buy brake cleaner, blue locktite, anti squeal compound, and caliper grease.
Clean everything with brake parts cleaner before you begin. Apply caliper grease to the pins and to all sliding surfaces, apply anti squeal compound to the back of the pads. I had to use needle nose pliers to hold the other end of the pins while I tightened them. Make sure you use a torque wrench; your life depends on those brakes working well
Old Dec 6, 2008 | 02:27 PM
St.Char's Avatar
St.Char
Make sure you push back the caliper piston before you close it. Otherwise, it won't fit over the new pads. I just used my old pad and with both thumbs, pushed back the piston. It also will help if you loosen the brake fuild cap to release the pressure.
Old Dec 6, 2008 | 02:34 PM
timd38's Avatar
timd38
You will love how clean your wheels will stay!
Old Dec 6, 2008 | 03:10 PM
speedraider's Avatar
speedraider
don't be surprised that the ceramics don't stop the car near as good as the z-51 pads, but they will stay clean.
Old Dec 6, 2008 | 04:40 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
For street driving, you won't notice any difference in stopping power and you will love the absent brake dust. If you take the car to the track, you will need other pads. The installation is simple.
Old Dec 6, 2008 | 05:47 PM
speedraider
,mr. dive and drive, I noticed real quick.
Old Dec 6, 2008 | 07:47 PM
06.Z51.MontRed.Vert's Avatar
06.Z51.MontRed.Vert
From: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
St. Jude Donor '08-'09
Did you bed the brakes properly? I'm real happy with the stopping with the ceramic pads, wasnt at first then followed the bedding procedure, big difference.
Old Dec 6, 2008 | 10:42 PM
Bludog's Avatar
Bludog
Not that I road race my car, and the only time I really drive it hard is at the drag strip, I did not notice any difference in stopping distance
Old Dec 7, 2008 | 08:59 AM
jschindler's Avatar
jschindler
It depends on which pads. I've had pads on non-Corvettes that I did feel a difference. I just put Hawk Ceramics on my Z06 and a friends. Both of us agree that we don't feel any difference from the factory pads. I'm sure on a race track it would be a different story. But I did six hard stops from 60mph to over 100mph within about a mile and they still felt fine.
Old Dec 7, 2008 | 11:02 AM
BlueSpeed's Avatar
BlueSpeed
Originally Posted by BEZ06
You've got 2 options: take off the entire Removing the pin is probably much easier. Here's a good thread with some pics:
Bob
On the front calipers just remove the TOP pin bolt (torque to 25lbs and add blue loctite unless you received a new bolt with your pad kit) and on the rear calipers remove the BOTTOM bolt so that you have more clearance, everything else is straightforward and easy.
Old Dec 7, 2008 | 06:14 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Huh? noticed what?
Old Dec 8, 2008 | 12:52 PM
jpgolf14's Avatar
jpgolf14
also, you may find that the factory pads stick to the caloper. a little "love tap" to release the pads is all you need. after that it is really pretty easy.
To Ceramic pad install
