Nitrous NOS on LS2
I have a dry shot kit i bought a while ago. my question is
a)should i use the dry shot and put the 100/150 shot right above the vararam filter
or
b)do a wet shot and tap in right after the throttle body (the problem is i have to buy the wet part)
i planing to keep the oem mass airflow sen
should i do dry shot or wet....?
or
should i do dry shot or wet....?http://forums.corvetteforum.com/c6-f...wet-shots.html
There are several other wet vs dry threads if you use the search function.
