Aftermarket A6 options
Here's the problem....MOST A6s fail because of the tuner. The trans is mostly understood by the guys trying to tune them.
It's NOTHING like the A4 WHATSOEVER. Internally, or from a software standpoint.
From the many tunes I've looked at, I get the impression that the tuners think it's an A4 or something.
While you might think your blower MAKES TOO MUCH POWER...Get better TIRES! cause the reason these transmissions break hard parts is cause most of you are forcing BLOWER POWER through a trans that trying to turn the wheels with 2.56 gears. It's like trying to run the quarter with a big chain tied to a tree.
The power is going in....and shredding the trans....cause it's not making it to the ground.
A (especially mine
) high ratio rear end will take upwards of 30% load OFF OF your poor stock trans and make sure it gets to the ground.The engine will rev quicker and UNDER LESS LOAD (take pencil and jot down this very simple but important fact for future use).
Sure, blowers work great...but when you mis match the application, YES VIRGINIA, YOU CAN HAVE TOO MUCH POWER.
Blowers for A6 cars are much like STEROIDS for people.
Yes, you can have TOO MUCH. YES, the stakes are high.
Yes, it looks good....UNTIL your kidneys fail.
Did you ever see one of those BIG steroid body builders with LITTLE SKINNY CHICKEN LEGS????
Kinda reminds me of an A6 car with a 2.73 rear end and A BIG BLOWER.
Chuck CoW
I talked to RPM about it. It just seems that no one is sure about a change or a build. Like how much power has one ran with this A6? Any new hard parts? No. It's difficult to justify spending $3000.00 to feel like a guinea pig. I know Rpm does great work but I need facts to drop that kind of money on a tranny. I could spend $1500.00 more and do one of there high horsepower proven A4’s with a stand alone controller. I am getting the tranny fixed now. (a trade costing me next to nothing) but I know it will be on borrowed time at my power level.
Here's the math:
A6
1st gear) 4.02 * 3.42 = 13.7484
2nd gear) 2.36 * 3.42 = 8.0712
3rd gear) 1.53 * 3.42 = 5.236
A4
1st gear) 3.06 * 3.90 = 11.934
2nd gear) 1.63 * 3.90 = 6.357
3rd gear) 1.00 * 3.90 = 3.90
A (especially mine
Chuck CoW
Here's the math I was referring to:
A6
1st gear) 4.02 * 2.56 = 10.29
2nd gear) 2.36 * 2.56 = 6.04
3rd gear) 1.53 * 2.56 = 3.92
A4
Christopher
Either I or he will be posting up the timeslip sometime this weekend.
Christopher
3.15s match up pretty well with Z51 M6 with the advantage of a lower first gear but you'll be turning a few more rpms on the highway.
Christopher
Also, what became of the 11.5 second limit? Did they kick you off the track when you ran 11.3???
When I got teched the second time the same guy who first told me that I couldn't break the rules ended up giving me grief because I *only* ran an 11.493 during the afternoon session.
You gotta love it - first they tell me not to break the rules and then hassle me because I didn't break them enough!
, the whole reason for the anemic 2.56 and 2.73 gearing was because of the big trans gearing in the A6 compared to the A4.
