Clutch Fluid
Old Dec 9, 2008 | 09:05 PM
CPG1962's Avatar
CPG1962
St. Jude Donor '09-'10
Default Clutch Fluid
I need to change my clutch fluid for the 1st time in my C6 Z06. What DOT 4 Brake Fluid is used? Is GM brand a must? Can I use a synthetic and does it make any difference?
I understand the ranger method as............
1. Remove fluid with a tukey baster or such.
2. Fill new fluid to fill line.
3. Replace cap.
4. Pump clutch 20-30 times.
5. Remove cap and check fluid for clarity.
6. If still murky color repeat all steps.
Can someone please confirm.
Old Dec 9, 2008 | 09:10 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
3. Replace cap.
Prestone DOT4 brake fluid seems to be the most popular.
Old Dec 9, 2008 | 09:20 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
I use Motul 600
Old Dec 9, 2008 | 10:58 PM
CPG1962's Avatar
CPG1962
Default Thanks and did I get it right?
Thanks for the recommendations.
Did I get the ranger method correct???
Old Dec 10, 2008 | 07:10 AM
walterm32's Avatar
walterm32
Go to walmart, get the prestone dot 4 brake/clutch fluid for under $3 and get a 2 stroke mixing syringe(sp?) for around $4. Its much better than a turkey baster
Old Dec 10, 2008 | 07:24 AM
mksz51's Avatar
mksz51
Yes - you have the method down. Be prepared to do this MANY times to get nice clear looking fluid again. Also be very careful with brake fluid and your paint. Brake fluid can eat paint quickly.
Old Dec 10, 2008 | 10:12 AM
Wayne O's Avatar
Wayne O
CF Senior Member
If you have some miles on your car and you haven't done this procedure before, don't expect to do it once or twice and be done with it. The first time you do it you might have to repeat the entire process 10-15 times. Once you start doing it regularly you won't have to repeat the process so many times.
FWIW I use Prestone DOT 4 for the clutch and Motul 600 for the brakes.
As mentioned, don't let the fluid get on your paint....use a mechanic's fender skirt. I 'mask' off everything around the clutch fluid reservoir so it looks like an operation at the hospital.
You might want to checkout Ranger's web site:
http://www.rangeracceleration.com/Burnout.html
Click on Clutch Care.
Old Dec 10, 2008 | 01:38 PM
CPG1962's Avatar
CPG1962
Default Thanks to all!
.......and Happy Holidays!
To Clutch Fluid
