flush clutch fluid
Old Dec 14, 2008 | 05:39 PM
Shade Tree's Avatar
Shade Tree
Default flush clutch fluid
I am trying to flush the hyd. clutch fluid. I have the cat off and the tunnel cover plate removed. I still don't see any type of bleed fitting. any help would be great.
Old Dec 14, 2008 | 06:01 PM
Shade Tree's Avatar
Shade Tree
Default bleed valve
Ok. I found the bleed valve. Near the 12 o'clock position of the small part of the bell housing. Now I just have to figure out how I am going to get to it with a wrench.
Old Dec 14, 2008 | 06:06 PM
timd38's Avatar
timd38
Good luck! LAPD had a clutch bleeding adapter that you can install when you replace the clutch.
http://www.thelapd.com/profile.asp?I...CategoryID=161
Old Dec 14, 2008 | 06:28 PM
Shade Tree's Avatar
Shade Tree
Default bleed unit
Thanks. I hope I don't need to replace the clutch too soon .
Old Dec 18, 2008 | 01:59 PM
Shade Tree's Avatar
Shade Tree
Default clutch bleed
After a lot of work bleeding the clutch I finally to it to the dealer and the clutch pressure plate is bad. $1750.00 estimate on the job. I have ordered the remote bleeding kit and they are going to install it for me. just wanted to let you guys know.
Old Jan 5, 2009 | 10:55 AM
Plano76vette's Avatar
Plano76vette
is there anyway the LAPD remote bleeder could be installed with out doing a clutch change?
Old Jan 5, 2009 | 02:53 PM
Shade Tree's Avatar
Shade Tree
Default bleed kit
Not on the C6. I don't know about C5. I have my car back now and everything is great.
To flush clutch fluid
