Wheel Studs
Old Dec 15, 2008 | 08:41 PM
timd38's Avatar
timd38
Default Wheel Studs
Has anyone ever replaced their wheel studs?
If so, how big a deal is it?
Thanks!
Old Dec 15, 2008 | 08:53 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I had a couple on the left rear replaced last year - too much for me to handle. It took the mechanic about 2.5 hours.
Old Dec 15, 2008 | 09:42 PM
Webz's Avatar
Webz
Fronts can be done on the car with patience but rears require the removal of the wheel bearings/hub (because of parking brake). Studs are splined so press out and press in replacement.
Old Dec 15, 2008 | 10:17 PM
Wayne O's Avatar
Wayne O
CF Senior Member
If you're using the same, stock length stud it's not that big of deal. You'll need some washers and and clamp to 'press' them into place. I went to longer studs on my front wheels and it entailed a lot more work. There was just no way a longer stud can be inserted straight into the hub without removing it.
Old Dec 16, 2008 | 06:17 AM
timd38's Avatar
timd38
Thanks! I like the long stud look and it is -4 with more snow predicted, so have all winter to get it done.
To Wheel Studs
