Ignition Switch Collapsed into Dash
Old Dec 16, 2008 | 02:25 AM
TeamYellow's Avatar
TeamYellow
Default Ignition Switch Collapsed into Dash
I have seen posts about this problem but couldn't find them using the search. My ignition switch on my 2007 MN6 came loose and fell into the dash recently. It was about 2125 miles and 2.5 months out of warranty so the dealer wouldn't fix it free. It cost $107 to fix and the dealership claims they have not ever heard of this happening.
If you have had this happen to you with a C6 or if a C5 has a similar rocker ignition switch, please reply and let me know. I posted here and in General since I am not sure which is the best place for this post. Thanks.
Old Dec 16, 2008 | 09:08 PM
Beach's Avatar
Beach
I had the same thing happen about 4 months ago, however I'm still under warranty.
Old Dec 16, 2008 | 09:15 PM
calemasters's Avatar
calemasters
The root cause is the retention tabs on the IP cluster trim plate. Call GM customer service and ask for the dealer's General Motors DVM to get involved. What the DVM says is the bottom line. Yours is not the only case.
Old Dec 17, 2008 | 08:05 PM
lockshed's Avatar
lockshed
happened to me also. I had a very technical friend fix it for me.
Old Dec 17, 2008 | 08:19 PM
saplumr's Avatar
saplumr
It happened to me once. Pulled the knee bolster off and pushed the switch back into place. Been fine ever since.
Old Dec 17, 2008 | 08:21 PM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Happened to me about a year or so ago, used a very thing scrrewdriver to pull it out, pushed it back into the slots, nothing since.
Bruce--Joyous Holidays and a Happy New Year--Jeff
Old Dec 17, 2008 | 08:32 PM
RoadRebel's Avatar
RoadRebel
Just grab the entire gauge cluster bezel, 1 side(at the switch area) in each hand. Then give it a firm tug towards you. It will unsnap and move forward enough to reach behind it and snap the switch back in.
Then, just snap the trim back in
30second tops
Phil
Old Dec 17, 2008 | 08:42 PM
saplumr's Avatar
saplumr
Same to you Jeff! Hope everything is going well.
Bruce
Old Dec 17, 2008 | 09:39 PM
LS1LT1's Avatar
LS1LT1
The C5 uses the more traditional key method.
Old Dec 20, 2008 | 02:34 AM
silvervette05's Avatar
silvervette05
107 bux..WOW..mine did the same thing when i let my mother in law drive it..she pushed it through the hole...she was freaking out..i jus pulled the dash off and pushed it back in..been fine ever since..
To Ignition Switch Collapsed into Dash
