speedo and lockout
Old Dec 20, 2008 | 01:39 PM
TRBO VNM's Avatar
TRBO VNM
Default speedo and lockout
Just finished a clutch change on an 07 C6.
The harnesses are all reconnected at the rear end, the fuses are good.
The speedometer does not move from 0. The reverse lockout also does not work. You are able to move the shifter all the way to the right while driving.
Any ideas?
Old Dec 20, 2008 | 01:50 PM
patton's Avatar
patton
St. Jude Donor '09
yea go back over a find out what ya missed or crossed
Old Dec 20, 2008 | 02:16 PM
TRBO VNM's Avatar
TRBO VNM
Default Done!
Found a connector that wasn't snapped all the way in. All works great now!!
Old Dec 20, 2008 | 02:22 PM
patton's Avatar
patton
St. Jude Donor '09
out standing and thanks for getting back on the fix
Old Dec 20, 2008 | 02:29 PM
TRBO VNM's Avatar
TRBO VNM
yeah, no problem. it was the speed sensor on top of the diff. hard to see or even get to. but got it and good to go. I assume the grounds are looped between the sensors because the reverse lockout works fine now as well.
thanks for the help
To speedo and lockout
