battery tender which one?
Old Dec 22, 2008 | 08:00 AM
mikeci's Avatar
mikeci
Default battery tender which one?
Hi All,
Happy Holidays to all. Winter finally came to lower New York state and it now doesn't look like I will be taking out my baby any time soon. It will probably be sitting in my garage until the spring thaw (I don't want to get all that road salt on the under carriage and all that aluminum). My question of the day is; Since the vette is not moving for a couple of 3 months do I need a battery tender and if so what should I buy?
Thank,
Mike
Old Dec 22, 2008 | 10:27 AM
CO Lightfoot's Avatar
CO Lightfoot
Yes, get a battery tender (not the same as a battery charger). Lots of products. I have a CTEK 3300, from a Forum vendor:
http://www.customcorvetteaccessories...rycharger.html
Lots of threads on this topic:
Old Dec 22, 2008 | 06:14 PM
jdurhan's Avatar
jdurhan
Just google "battery tender plus" it runs about 59.95, it's one of the most popular. I've got one and it works perfect.
Old Dec 22, 2008 | 07:56 PM
B-Pete's Avatar
B-Pete
Default Battery Tender
I recommend the "Battery Tender" brand. I use the two bank model.
Old Dec 22, 2008 | 10:21 PM
C5pilot's Avatar
C5pilot
I'm using the Sears Diehard tender, $19.99. Comes with all the different quick connectors and works just as well as the higher priced units. My battery died 3 times the first year without it. No problems since.
Old Dec 22, 2008 | 10:56 PM
jpee's Avatar
jpee
I got a "Deka" ?? from Carquest.. for $39.00 it will charge until the battery is fully charged, then just "Maintain" that charge.. it has three lights
Red to show its plugged into 110V outlet
Yellow if its charging the Battery
Green if the battery is charged, & its just maintaining the charge
I've had it 3 yrs with NO problems... I'm not sure how this price compares to the ones sold here.... but mine works fine.. and C5Pilot is doing ok with an inexpensive unit..
Its your $ and your car...bottom its also your choice... but you do have a large selection and prices that vary widely!!
Maybe someone can enlighten me.. unless you are in Donald Trumps income bracket why spend $70 for something you can get for less than $30 if they both do the same job ??
Old Dec 22, 2008 | 11:08 PM
tdelena's Avatar
tdelena
St. Jude Donor '12, '14-'15, '17, '20
I bought one of these at walmart for $45.
http://store.schumachermart.com/sc-1200a.html
Old Dec 22, 2008 | 11:22 PM
Windward08's Avatar
Windward08
I bought a Schumacher tender at Walmart for $19.95
http://store.schumachermart.com/sem-1562a.html
I can leave this connected all the time.
Old Dec 23, 2008 | 01:17 AM
bosco 08's Avatar
bosco 08
i have had 3 of them for the last 4 years use them for my car, bike and lawn tractor. they work perfect and are much cheaper than the over priced Battery Tender and the others on the market plus it helps support Tony Schmachers Top Fuel Car.
Old Dec 23, 2008 | 10:45 PM
siffert's Avatar
siffert
You should get a tender that also DESULPHATES the battery-makes it last longer. The Battery Minder Plus and a few others do that.
http://www.batterymart.com/p-battery...y-charger.html
Old Dec 24, 2008 | 07:32 AM
C6VetteMan's Avatar
C6VetteMan
This one plugs into the cigarette lighter ans only charges when the voltage falls below 12v.
http://e-partssales.com/Merchant2/me...electronics997
Old Dec 24, 2008 | 09:12 AM
Rednblack's Avatar
Rednblack
Battery Tender Plus - doesn't get any better
Old Dec 24, 2008 | 09:23 AM
02HREBlue's Avatar
02HREBlue
Second the Battery Tender Plus
Old Dec 24, 2008 | 10:48 AM
mikeci's Avatar
mikeci
thanks guys for all the advice I'm going w/ the battery tender plus and I'm buying at Autogeek. I might have found it cheaper somewhere else but they have done very well by me w/ all the advice and help on cleaning my cars.
Mike
Old Dec 25, 2008 | 01:54 AM
Gold Z's Avatar
Gold Z
Veteran: Marine Corps
I bought my battery tender at Harbor Freight for $5.99. It's been working great for the last six months or so on my seldom driven Camaro.
Old Dec 25, 2008 | 09:32 AM
MurphMan2's Avatar
MurphMan2
Bought the BatteryMinder as it supposedly desulphates the battery and makes them last longer.
Old Dec 25, 2008 | 10:38 AM
GotChrist?'s Avatar
GotChrist?
Automatic battery chargers do not fully charge the battery. They take it to about 85% and leave it there. Intelligent chargers like the BT+ are 3 stage: bulk, absorption (85-100%), float.
They change current and voltage, not voltage or current alone.
Vector explains theirs along with desulfation
http://www.battery-rechargeable-char...-brochure.html
http://www.electric-cars-are-for-gir...y-charger.html
http://www.superiorcarcare.net/btplus.html
I can't find a certain page that went into great detail about the various modes of chargers and how they work and what they do. Suffice to say it was over my head. I just know that a stage is minimum and an intelligent one at that.
I have a CTEK and it's very nice. It does what its supposed to do. Does it do what the BT+ does, I dont' think so. The BT+ will exercise the battery for lack of a better term to keep them going well past their expected life cycle.
I have two motorcycles. One battery has been in two bikes. I've had it for at least 8 years. Odyssey batteries and Battery Tender Plus chargers. On the negative side I don't know what I'm doing wrong, but I keep breaking the BT+ every year and a half or so at least that's all the last one lasted. Shipped it off to them in FL and they sent a new one. The first one lasted me 6 years plus. I don't know if it's the Oddyssey is so old it is taking the BT+ out or whether its the stuff in-line with the power cord. I have had it plugged into a professional EMI/RFI protected work bench which is plugged into the same garage outlet as my air compressor. I've even put a surge protector between the charger and the work bench which has all its outlets protected. Beats me. I do know they do what they're supposed to do and that is extend the life of the battery, not just keep them charged.
To battery tender which one?
Old Dec 26, 2008 | 01:55 PM
vettenut's Avatar
vettenut
KY Events Coordinator
Default Battery tender
I use the Battery Tender Plus and is work great. Attach it a forget it!
Old Dec 26, 2008 | 08:01 PM
JohnDS's Avatar
JohnDS
Me too, very happy with it.
John
Old Dec 26, 2008 | 08:22 PM
T VETTE's Avatar
T VETTE
John
Don Schumacher will be very happy to hear this. The price of NITRO for the Army Dragster team has really gone up, good for sales.
