What are your LS2 #'s and with what mods?
#41
Standing Mile setup, Mods in Sig...
30,000+ mile stock LS2 short block, NEVER removed from the bay
761rwhp 645rwtq on boost only
Haven't made a N2O pull with this current setup, I feel that the engine wouldn't care for it much...
#43
C6 A6 362/358
LPE Intake,LG Pro Long Tubes
Car currently at Vette Drs getting a Vortech T trim install. Will post up new numbers next week.
Install done 505rwhp/440tq
#45
Guest
Posts: n/a
Your numbers reflect a well thought out combo.
#48
#49
St. Jude Donor '08-'09-'10
those rather impressive numbers. Would also appreciate if you can post the dyno sheet. I would appreciate the info as I am planning my H & C build. Thanks, Leon
#50
VIDEO
http://www.youtube.com/watch?v=pTvCr....php?f=8&t=671
Since adding the Comp Cams reverse split cam and most recently from a ported oem to a ported FAST 90/90 (retuned) and a Textralia OZ-700 single disk clutch here are the numbers to add to the internal mods list as i am already on the bolt-on list with my 11.98 @ 116.44 - C6speedjon - 07 Z51 M6 -CAI, CB, hdrs, ported int/tb, tune DR - (1970) ....
The cam is a Comp Cams reverse split style 228/222 588/581 114.5
So its a;
07 Z51 M6 - Comp Cam, Vararam, Corsa sport Cat Back, LG motorsport headers, Ls2 port works ported FAST90/90 and Ls2 ported throttle body, Straightline tune, on mickey thompson 275/40/17 DR
These numbers are from Straightline Performance's Mustang dyno;
415 RWHP
391.7 RWTQ
On M/T 17 inch DR's
3210 raceweight (3410 w/me in it)
This was at Byron Dragway in Byron, IL Nov. 1, 2008
60' 1.632
330 4.757
1/8 7.314
MPH 96.96
1000 9.508
1/4 11.354
MPH 121.70
So its a;
415 RWHP
391.7 RWTQ
On M/T 17 inch DR's
60' 1.632
330 4.757
1/8 7.314
MPH 96.96
1000 9.508
1/4 11.354
MPH 121.70
#53
Those are pretty good numbers using stock modified heads. I wonder if you can share how much milling and head gasket you used to achieve
#54
2006 A6, 546 rwhp / 476 rwtq @ 9 lbs. boost
A&A S-Trim SC Kit
Dyno Tuned by Charlie Williams at RPM Motors
Z06 Exhaust Manifolds, Cats and H-Pipe with Corsa Sport Mufflers
A&A S-Trim SC Kit
#57
