got it working but on startup theres this weird hesitation noise with the V1...is this normal? (v1 is new and with the cig cord works fine)
wondering if this little bit of hesitation from the V1 is because of the cranking of the engine? i got the green wire all the way down but the yellow is only half way down....but it does get power to it and its working....
all im asking is if the detector powers on then i should be good right?
I use the invisicord w/ the V1. There is a momentary hesitation with all the lights, DIC displays, etc including the beep-beeps from the V1 until the engine turns over and sends current to the rest of the car. Is this what you're referring to? If so, IMO it is normal.
