Battery Tender - Need Help
1. Can anyone provide advice which battery tender is the best unit to purchase and
2. any advice where to install it under the hood.
3. If you know where to purchase it would be very helpfill.
Thanks for any advice you may be able to provide.
You can buy cheap trickle chargers under various brand names, but a, "Battery Tender," is the ultimate. It is programmed to charge, float charge, trickle charge, or do nothing at all; depending on the state of charge in the battery. It's not just a trickle charger; which most others are.
I know this sounds like I work for them, or have stock in the company but the fact is I don’t even own one of their products. But I have looked into the concept, and when I need one; a Battery Tender is the only brand I will consider for the safety, and longevity of my battery.
This is just my opinion, but it seems a lot of people are using the term, battery tender, when they are really just talking about trickle chargers.
Google, "battery tender," They are the first, non sponsored link.
Ed
http://forums.corvetteforum.com/c6-t...which-one.html
I use a CTEK 3300. Works great, no issues.
IIRC, there's a thread that discusses installation. Knowing what I know now, keep it simple -- alligator clips work fine. Quick-disconnect fitting also works fine and is convenient if you drive occassionally. I leave the hood unlatched to remind me to disconnect before driving off.
Some debate about where to hook 'em... follow the jump-start diagram? I simply connect directly to the battery posts. No problems.
