TEA LS2 STG2 head pics
They flow excellent and I could'nt be happier since they only cost $1,000 since I had my Patriot springs already. This car is so easy to work on, I wish you guys would tear into them more. They are very easy to mod.
I know everyone loves car **** so here are a few pics and if you look close enough, you will notice ARP bolts used for the excessive ammounts of N20 that I will run through this car.
It should run well now, all I need is the Spin/FAST and a 150-200 shot.
Enjoy
They did forget to give me the damn coolant plug that goes in the pass head. I tried tracking it down today and I hope the dealer has one tomorrow. Im not going to have a new tune until the Spin/FAST is on so I wont have any numbers right away.
Motor is in a 2002 Z28, on a Mustang Dyno it put down 460rwhp@7100rpm/400rwtq@5950rpm. With the vehicle weight and areodynamic coefficient for a 2002 Corvette it put down 489rwhp@7200rpm/440rwtq@6000rpm. I only did that to compare Apples to Apples with a similar LS6 engine we did. I wasn't too concerned with the dyno numbers though. . .With 60lbs of fuel pressure, I'm using 76% of the Injector Duty Cycle. That puts the fuel consumption right where I thought it should be for the crank HP I was looking for.
I just completed that stage of the build in October, and the car used to be an automatic, so it still has the stock 3.23:1 rear end so I haven't taken it to a track yet. What I can say is that the power comes on VIOLENTLY at 4500rpm or so. So fast in fact that the factory tack can't keep up. I have to shift at 5800rpm into 2nd as to not to hit the 7500rpm rev limiter according the the factory tach. While shifting into 3rd at 96mph, it'll still spin the tires until you let off.
Wheels/Tires/Rear End/Suspension will be installed this Spring, then it'll be ready for some track time. Here's some dyno video of the car:
http://www.youtube.com/watch?v=wOi9wXD1aYs
http://www.totalengineairflow.com/pr.../gmhead/gmls6/
I threw the car back together and had to drive 4 hrs the very next day, hows that for confidence in your work?
The car is VERY quick now. I was driving @ 84-85 (HUD) mph and hit it and litterally in a few moments (4-6 sec) I was @ 131 (HUD) mph and let off! The car is totally undrivable from a roll under 30mph and it will spin the tires @ 40mph while in S mode holding 2nd gear with new KDW's. Mucho fun now and it would run even better with a new tune but Im going to wait for the FAST.
Anyway, its so much better than when it was stock near 5 months ago and I want to encourage you guys to tear into these cars. Stock they suck so bad.
