wheels
Old Jan 9, 2009 | 01:52 AM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Default wheels
do i have to change offset of rear wheels if i go to a 19"/11"?
Old Jan 9, 2009 | 02:15 AM
cya's Avatar
cya
St. Jude Donor '13
In most cases no if you have the right tire size; do a search many posts on this topic. Oya also factor in lowering if you have done so already.
Good luck with your vette.
CYA
Old Jan 9, 2009 | 06:00 AM
CPG1962's Avatar
CPG1962
St. Jude Donor '09-'10
Default Wheels
I beleive it varies from one wheel to the next. The mfg should be able to tell you.
Old Jan 9, 2009 | 10:58 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Will you use larger than stock tires on the 19 x 11 rear wheels? My CCW street wheels are 19 x 11 rear used with Z06 sized supercar runflats. The offsets are different...not the same as stock C6 wheels. Talk with your wheel vendor or manufacturer, they should know what to do.
Old Jan 9, 2009 | 08:21 PM
C6 CYAA's Avatar
C6 CYAA
You should use the stock offset (79mm) if you are going from 10" rear to 11". The new rim will project out 1/2" past stock and 1/2" inside.
See the offset calculator below:
http://www.1010tires.com/WheelOffsetCalculator.asp
9-1/2" fronts and 11" rears
To wheels
