Issues Removing Crank Pulley Bolt
Old Jan 13, 2009 | 12:36 AM
gath47's Avatar
gath47
Got a 1/2" x 18" breaker bar from Harbor Freight for $12. Put the car in 6th gear and the rubbery slack was reduced to about 1/8 turn. A few pulls made me realize I was going to whack an elbow once it lets go with the force required. I added about two more feet of leverage with my jack handle and "pop" the bolt calmly breaks free. I take it out and there is red locktite on the shaft and inside of the head. Now to get that pulley off!
Old Jan 13, 2009 | 08:51 AM
AintQik's Avatar
AintQik
If you are not going to pin the crank use a new bolt. Comes with red stuff on the head. Supply your own loctite. With the crank pinned all this becomes insurance not vital action.
Shh, don't tell but with my crank pinned I've 'gasp' reused the original bolt 3 times Before, with new bolts and no pin, I lost the balancer 3 times. I shift hard.
Old Aug 11, 2014 | 11:10 AM
mfoti's Avatar
mfoti
I am about to remove my ARP crank bolt that has red loctite on it. I am in for a nightmare? I have an impact wrench and i a plan on heat with a mapp gas torch. Any suggestions? how long do i need to heat the bolt?
Old Aug 12, 2014 | 09:05 AM
MARSC6's Avatar
MARSC6
I ended up having the trans in reverse with someone pushing on the brake while I used a breaker bar and a pipe to extend the handle.
The bolt laughed at my brothers 1/2" Snap on impact at 150psi. Then I laughed at him for spending so much just for the Snap on name
