C6 Storage-battery
Old Jan 14, 2009 | 08:36 AM
Fredvettec6's Avatar
Fredvettec6
Default C6 Storage-battery
New C6 went from dealer to storage - no road time. Currently on a battery charger (DieHard) w/maintain mode capabilities. Any concern on overheating/overcharge? What if I set a timer so the charger was only on for specific times and length of charge?
RSVP,
FredvetteC6
Old Jan 14, 2009 | 11:05 AM
Michrider's Avatar
Michrider
Get a Battery Tender Plus. Only way to fly.
I wouldn't use that other charger for long term. Probably work fine, but the Battery Tender Plus is a no brainer, plug it in and leave it. Years and years of countless people using the Tenders with excellent results, can't go wrong with that.
Don't mess with timers. The Battery Tender is a plug it in and leave it deal.
Old Jan 14, 2009 | 11:15 AM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Why not just disconnect the battery?? Those batteries have shelf lifes of several years...
Old Jan 14, 2009 | 01:28 PM
speedwaywhite's Avatar
speedwaywhite
Battery will need to be charged regularly even if it is disconnected. At room temp battery will self discharge at about 10% a month, lower temps will slow discharge higher temps will speed up discharge. If battery sits for extended periods in a discharged state it will sulfate, lose most if not all of its capacity. A totally discharged battery will freeze in winter and the case could break leaving a major mess when it thaws.
Old Jan 24, 2009 | 07:17 PM
Fredvettec6
tHANKS FOR THE INFO. WHO MAKES THE BATTERY TENDER PLUS?
Old Jan 24, 2009 | 10:40 PM
chevybob's Avatar
chevybob
Here is CCA web site. I just purchased one.
http://www.customcorvetteaccessories...rycharger.html
Old Jan 25, 2009 | 11:06 AM
85Z514+3's Avatar
85Z514+3
To C6 Storage-battery
