LS3's with headers come inside ...
Using the above example which gained 28hp, did the $1800 headers gain 8hp and the $400 tune 20hp? Could you have gained 20hp with just the tune or only 15hp? Maybe the headers were good for 18hp and the tune the last 10hp. Your guess is as good as anyone's.
There's no way to know when you do several mods at the same time, which ones really helped.
To use the Z06 mufflers on a std. C6, simply cut the Z06 pipe off the muffler leaving about 3/4" remaining. Then cut the std. pipe off the std. muffler as close as possible. Slip the std. pipe into the tapered stub on the Z06 muffler and weld in place.
Untuned w/o headers vs. tuned w/headers is not apples to apples.
- LG make more torque below peak, but don't fit as well and are a pain since they have slip fit connections.
- ARH & Kooks are both easy to install and don't have the slip fit connections. I like ARH because (IMO) the quality of the construction is better.
When you do headers, make sure you do the intake at the same time. If you can't get the air into the engine, there's no sense in trying to get it out easier.
Since it looks like you're the kind of guy that really wants a good performing car, I'll tell you a few mods that most people like to keep secret.
- Pulstar plugs will add about 25 RWHP
- Vararam throttle body spacer adds 10 RWHP
- Tornado is needed to see any of these gains. Most people skip this step and then complain when they get low a dyno number.
Oh, if you get these mods done and don't see the gains you expected, just take your car to another shop and get it dyno'd again. Sometimes the first dyno session doesn't take and you have to do it a couple of times. Try different shops each time. It's better that way.
Take care and good luck. Be sure and come back and tell us how it all works out.
-Ben
-Ben
Halltech
Tstate 160
Tune
441rwhp / 435tq
No there all like he posted in your quote! 2 1/2 inlet. Z-06 has 3inch to the muffler that is swaged down at the inlet! I was 372 370 stock then 421 410 with headers, then z-06 mufflers,423 417 msd wires plug tune gave me a best N/a of 433 428 on a day with unreal air. Get the 1 7/8's if you do! 3 inch x-pipe!
-Ben
I was on the fence regarding headers, because the price per hp didn't seem too well established. These two examples average about $85/hp. While a little on the high side, it's still a lot lower than NPP at $200/hp. Now all that's left is to find where I hid that mod money.
Joe Blows car made 440 HP on a Dyno, Great, how much time does he spend running his LS motor @ 6,500 rpm.
