LS3's with headers come inside ...
Old Jan 17, 2009 | 05:43 PM
  #41
punky's Avatar
punky
Banned Scam/Spammer
Originally Posted by HOXXOH
I think we all understand that 6500 rpm happens for only a brief moment prior to a gear shift. But for purposes of a reasonably scientific comparison, HP remains the method that Joe Blow uses to evaluate his interpretation of fun. Your definition of fun may be different.
What makes any car fun is low to midrange torque. Horsepower sells cars and torque provides the fun factor, allways has and likely will for the forseeable future. Judging an engines true performance by the peak HP #s is for guys who know only what they can read in the auto press periodicals. Lots more to it than that. The import small displacement motors can put up some respectable peak HP #s on the almighty dyno but have to be run like a chainsaw to get them. They disappoint in the real world and feel gutless because they lack torque.
Old Jan 17, 2009 | 10:59 PM
  #42
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Originally Posted by BrooklynC6
Im debating what to do with my car and would apprieciate if anyone running LS3's with headers ( whatever brand ) could tell me what kind of power/tq you picked up with the headers alone .
Thanks !
Like many have said, if you're doing headers,make sure you at least do the a cai and retune.
If I think back, I believe my #s with VR, Dynatech 1 &7/8s, Borla Touring, and a Dyno tune with a mix of 91/Torco was 448 RWHP and 44X somthing TQ.
JB
Old Jan 17, 2009 | 11:06 PM
  #43
HOXXOH's Avatar
HOXXOH
I sense your definition of fun is cruising along and then going WOT or less in the 3000-5000 rpm range.
Other definitions include WOT from a dead stop for 1/4 mile, high speed lateral thrust, flat out high speed, serious braking, show and shine, and casual cruises.
A Cat powered Kenworth has 550hp and 1850tq, but it's still not fun for everyone.
Old Jan 18, 2009 | 07:01 AM
  #44
punky's Avatar
punky
Banned Scam/Spammer
Trucks are geared to overcome 70,000+ lbs of resistance. Put half that tq in your Corvette and you would care less about "peak" HP #s from a dyno. The area under the torque curve is far more important than what the friendly dyno operator shows as a max HP figure. What makes a performance car fast is the TQ that determines HP as a function of rpm.
Old Jan 18, 2009 | 07:11 AM
  #45
SpinMonster's Avatar
SpinMonster
To use the Z06 mufflers on a std. C6, simply cut the Z06 pipe off the muffler leaving about 3/4" remaining. Then cut the std. pipe off the std. muffler as close as possible. Slip the std. pipe into the tapered stub on the Z06 muffler and weld in place.
I have LG headers with 3" pipes as they have for Z06 applications and this same pipe allowed me to use the Z06 catback with its existing pipes so when you decide you want headers simply get the Z06 version headers whcih then have 3" pipes all the way back for use with the Z06 catback and no cutting of pipes has to happen. You dont get the C6 base version if you know youre getting the Z06 catback.
Also, although the inlet to the mufflers is 2 1/2 inches it still flows more to not have a 2 1/2 inch x-pipe. A 2 1/2 inch x-pipe is still a flow restriction of its own.
Old Jan 18, 2009 | 11:22 AM
  #46
tomiboy's Avatar
tomiboy
[ The import small displacement motors can put up some respectable peak HP #s on the almighty dyno but have to be run like a chainsaw to get them. They disappoint in the real world and feel gutless because they lack torque.[/QUOTE]
How true! I had a 04 Honda S2000 that had 240 HP in a 2800 lb car, but it had nothing unless you kept it between 6.5 - 8K RPMs at all times
Old Jan 20, 2009 | 01:11 PM
  #47
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default AS I Recall..........
Any dyno numbers ?
Hey man.... AS I Recall.......... C6Devil (hope I don't get banned for using his name here) had a pretty nice running LS3 with a Vararam, LG's, and a nice tune from me.
I forget the #'s, but it ran really well and I do know that Eddies got some dyno sheets for it.
Check with him...
Chuck CoW
