Z51 Help!!!!
Old Jan 17, 2009 | 05:52 PM
c6_noob's Avatar
c6_noob
Default Z51 Help!!!!
Found a 2006 I am looking to buy and the seller does not have it listed as a Z51, however it does have the cross-drilled rotors in the pictures...
Is there any way to tell whether it is an official z51 package by the VIN?
1G1YY36U865130975
THanks a bunch!!!
Old Jan 17, 2009 | 07:52 PM
REVAK's Avatar
REVAK
Default Z51 ?
1G1YY36U865130975
THanks a bunch!!!
It may well be , my 06 Z51 vin has the same first 8 characters . I believe they are the descriptors, but maybe someone else can verify this.
Old Jan 17, 2009 | 07:55 PM
muskaroxs's Avatar
muskaroxs
when you go look at the car look at the glove box there should be a code that would state whether it's a z51 or not.
Old Jan 17, 2009 | 08:19 PM
c6_noob's Avatar
c6_noob
Default what would that code be for z51?
if my understanding is right, only the z51 came with the drilled rotors...
Old Jan 17, 2009 | 08:34 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
actually, I believe the F55 suspension option also came with drilled rotors. plus, anyone can put on drilled rotors, so to me, that isn't the criteria to use. check the option sheet and see if Z51 is listed. if it is, you know you got it.
Old Jan 17, 2009 | 09:18 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
Old Jan 17, 2009 | 09:38 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
1G1YY36U865130975
THanks a bunch!!!
The best way to tell is to look at the gap between the brake caliper and the wheel. The Z51 uses the same caliper, but has a bigger rotor. So, the gap on a Z51 is smaller than non Z51 brakes. The gap on the non Z51 brakes will be about 3/4" or plenty of room that you can stick your finger between them, with a little to spare unless you have really fat fingers. On the Z51, the gap is way to small to put a finger in it.
I'll go get you a couple of pics to show what I mean.
EDIT: PICS
NON Z51
Z51
Old Jan 17, 2009 | 09:44 PM
pmj341's Avatar
pmj341
why not go to the Vette registry and research the Vin??
you have the Vin
Old Jan 17, 2009 | 11:23 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Get the seller to send you a digital photo of the option label in the glove box. It will have all the option codes including Z51 you are asking about.
Old Jan 17, 2009 | 11:26 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
In '05-'06 only the Z51 had the drilled rotors. '07+ Z51 and F55 had drilled rotors. Don't go by the brakes as your one and only indicator.
Old Jan 17, 2009 | 11:44 PM
timd38's Avatar
timd38
Ditto
Old Jan 18, 2009 | 02:32 PM
kevo349's Avatar
kevo349
p.m. sent it does have z51
Old Jan 18, 2009 | 06:49 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
The sticker in the glove compartment is the "service parts identification"
and lists the VIN and all the codes that apply to that specific car's equipment. One of the codes shown will be Z51. If it isn't there you don't have a Z51 equipped car. Cross drilled rotors don't always tell the story because they are sometimes added as a dealer installed option on non Z51 models. The only other way to find out is to cross reference the VIN to it's build sheet which shows the Z51 option.
Old Jan 18, 2009 | 10:04 PM
exracer28's Avatar
exracer28
1G1YY36U865130975
THanks a bunch!!!
If you have a decent dealer service department they can look up the vin and tell you the as built options.
Old Jan 19, 2009 | 02:52 PM
c6_noob's Avatar
c6_noob
Default Thanks everyone!!!
Thanks for your feedback... Gonna get the car this Saturday...
I'll post some pics and formally introduce myself to the forum once i am a legit C6 owner this weekend!!!!
To Z51 Help!!!!
