2007 A6 temp reading
Old Jan 18, 2009 | 02:49 PM
abc 123's Avatar
abc 123
Default 2007 A6 temp reading
What would be causing the temp display to be XXX? And yes, it has been running enough to get warm.
Old Jan 18, 2009 | 03:12 PM
LS1LT1's Avatar
LS1LT1
Hmm, never heard of that happening to anyone before.
I'll give one of my standard suggestions, maybe disconnect the battery for a while (I like to give it overnight but certainly a few minutes to an hour will do as well) and then reconnect it and see what happens, it could clear it up. Otherwise you might need someone to look at it with a scan tool/code reader.
Old Jan 18, 2009 | 05:16 PM
Vette_DD's Avatar
Vette_DD
Did you try using the RESET button?
To 2007 A6 temp reading
